BLUENOSE by PIERO
About the 2 sides on top of the keel, Johan mentioned, this alert was made:
The bevel on the 2 side pieces must be on the inside: |\__/|
I did is also wrong and pointed them /\__/\
The bowsprit will be placed between the chamfers.
Thanks Peter, I had already seen the incongruity of the external rather than internal bevel. When I'll mount the two bulwarks , I will also modify the bevel to correctly receive the bowsprit.
Having left my BN in the main lab, I continue to assemble the small parts available in the secondary lab.
Today I finished covering the base provided by YQ with 7x1,5mm pear strips and I also put some treenails using the usual toothpicks since I didn't use them on the frames.
Then I made the masts terminal using a small homemade lathe ...
See you for further reports
That is a foundation that makes your BN very happy to stand on. :) And of corse: I like the treenailing!
Good looking stand. Just a little more work and the Bluenose will be sitting there proudly.;)
