• At some point from current UTC of 19:40:30 Thursday up to UTC 19:40:30 Friday, it is possible the forum might be disabled for a short period of time for updates and upgrades. Another notice will be posted for status. Note: Central Standard US time would be 14:40:30 Wednesday up to 14:40:30 Thursday
Charles Royal Yacht, 1674, Scale 1:64, by Woody Joe (Japan)
Good evening, all.
Many thanks to all of you for your comments and 'likes'! I am happy you supported my decision to re-do and follow along with the log updates! I am also happy that some of you may use the techniques described here in your current or future builds.
I have a few hours in the evening so I can continue with the cannons re-do. A few days back, we completed the wooden part of the gun, and today, we will start the metal components part. We will make all the parts from scratch (except the barrels which I bought). So, let's begin with the barrels.
The barrels come with the trunnion also turned CNC (a nice touch). I will use the hard (easy) solder and torch to solder trunnion into the barrel. Using the cut-out dick to make a deep groove for a piece of solder. This way the solder will melt inside the barrel making the outside nice and clean. The spots you are seeing in the below (right) image are oxidation as a result of heat.
View attachment 395481 View attachment 395482
While the barrel was still hot, I gave it a bath of vinegar, to remove accumulated oxidation. Vinegar acts as the acid and cleans brass. One of the barrel enhancements is to make the Pan (touch hole or vent). The problem, however, is I would have to use 0.2mm endmil. I do have such a mill but only one and was afraid to break it. But... I succeeded without fail. I like the results. what about you?
Here is how the gun looks today after fitting the barrel on the carriage.
I couldn't resist trying out this gun (as is) on the model to make sure it fit on the deck and in harmony with the rest. I think it looks better...but we shall see once the gun is fully assembled.
That's all for this evening, folks. Yeah, the time flies... Thanks again, all to be continued... ;)
P.S. The last image to answer the question of Yuri @Y.T. How I made multiple parts at once. The photo should explain.
This is a very good job, Jimsky. Thanks for sharing this knowledge and work.
Nice job, Jim! I would be afraid to drill the touch hole. I’m finding it hard to find good tiny bits. I guard the one I have with my life! Where do you get your bits?
Thank you, Vic. Honestly, I was also afraid to mill such a tiny line on the metal. But, I feed extremely slowly and do not plunge the endmill too deep. The part is firmly held in the machine vise. I also use one of those magnifying lenses (below) to control the job. I don't know how much magnifying it does, but together with my overhead magnifying 2.0x it works OK.
I should say that most (if not all) of my endmills, I buy from Aliexpress. They are an excellent quality to mill wood and non-ferrous metals (brass, copper), and they are much more affordable if sourced elsewhere. My biggest upgrade to the MF70 is the replacement of the spindle with an ER11 collet, this is not just a fancy name, it enables to use of a broad variety of endmills. For example, on a 4.0mm shank, you can have mills from 0.2 to 4.0mm. That means you can use all the bits in this range without changing the collet. And yes, they are a decent quality for our hobby. we recently had a discussion about where we purchase our still bits. I will try to find it...
Thanks again.
Thanks again.
That must be a pretty amazing collet. Do you have a picture?
What a beautiful work Jimy, I look forward to further updates to learn a lot more. Oh yes, I am sitting next to Roger because he is not alone on the side he has chosen.
Thank you, mein Freund. There are plenty of seats today, as many members left this log due to long-time inactivity. and you are most welcome.
Witaj
Piękna praca z lufami i wózkami . Jesteś mistrzem frezowani umiesz wykorzystać narzędzia którymi dysponujesz . Pozdrawiam Mirek
Thank you, Mirek. I mentioned in my different posts that my Proxxon mill became my table tool, I mean it is always next to my right hand and ready to execute tasks. Definitely not a master, but I learn every day something new from other members who know the milling job better. Also, the lack having other mechanical tools, like a lathe, makes me sink a bit 'out of the box' ;)
I am preparing some images for the next step in re-doing the naval guns and will post them in a few days... Stay tuned. :)
Greetings fellow modelers. First, I'd like to express gratitude to all who show an interest in the build log, and your comments and reactions made.
Just to recall what we left off in our last session as part of the metalwork. We prepare the barrel by soldering the trunion and milling the touch hole. Here is the naval gun today.
Immediately, I wanted to see how the barrel would look under blackening and Royal emblem. I found that the blackening results greatly depend on how well you have cleaned the parts. If you look at the above image, you will see the barrel 'shines'... yes, it is because I use one of those abrasive brush nylon buffing/polishing wheels bought on Aliexpress. They come in various grits distinguished by colors. The 320 grit is great for cleaning oxidation and small imperfections, it will not 'eat' the pattern, while the 600 grit wheel is great for polishing.
Here is the link, in case someone considers using them
Back to the blackening barrel... After using the polishing wheel, I used the steel wool on those parts the wheel couldn't be reached. To finish with cleaning, I use Windex and the old toothbrush, following the rinse with clean water. To blacken, I use a Brasblack solution diluted with water. To finish with the barrel, I glued the Royal emblem and lightly brushed it with graphite powder. Below is the result.
The next logical step is to make the capsquare itself and all the parts to attach it. I use the brass strip from my stash 1.00mm wide and 0.3mm thick. It was obvious I would need a few more jigs to make the work easy. Let's start with drilling/milling jig. A scrap of pearwood is used to mill the grove exactly 1.00mm wide and 0.3mm deep (as the dimension of my strip) so the strip can just slide while in place. The top slides along the jig and the miniature bolt holds the brass plate while machining.
Here is the enlarged view. Please note the notches, the first two will be used later when we need to bend. The Third one is where we need to drill the hole and the last one is the length of the capsquare workpiece (blank).
Now we can do some machining. Originally, I planned to use just a hole to mimic Capsquare Joint Bolt, but lately, I have a decision to make it real. I used a 0.2mm endmill to mill the grove. Also, the hole was drilled using the same endmill and then enlarged with a 0.35mm drill bit. Below are photos to depict the process.
Milling was rather time-consuming because of the tiny endmill, I couldn't plunge too deep and move too fast. But...the results were fully satisfactory and I didn't regret spending time making them. While the blank in the jig, I made saw the mark notches, later, they will serve as the guide while bending.
The next is to make a bending jig. I have made those in the past, so this was not difficult just a different size. The image is self-explanatory. It will work like a press.
Here is the jig in 'action' The blanks are oriented exactly where the saw notches in the middle. In the image, they are on the bottom so you cannot see them.
Carefully close the jig (not to move the blank), and squeeze the entire jig in the wise. Ever wonder what happened? Check the next image. After some time you have some capsquares ready for blackening.
I have rather big fingers... To be continued... later today
The next logical step is to make the capsquare itself and all the parts to attach it. I use the brass strip from my stash 1.00mm wide and 0.3mm thick. It was obvious I would need a few more jigs to make the work easy. Let's start with drilling\milling jig. A scrap of pearwood is used to mill the grove exactly 1.00mm wide and 0.3mm deep (as the dimension of my strip) so the strip can just slide while in place. The top slides along the jig and the miniature bolt holds the brass plate while machining.
View attachment 401952 View attachment 401953
I have a rather large finger... To be continued... later today
my dear friend, thank you very much for the information and the pictures, it's very helpful
Witaj
Bardzo ciekawy instruktarz lufy poczernione idealnie a drobnica rewelacyjna czekam na więcej . Pozdrawiam Mirek
Beautiful workmanship Jimsky,
Did you anneal the brass before you pressed it?
Cheers,
Stephen.
Amazing, Jimsky. Looks like a masterpiece. How many cannons she has?
my dear friend
can you give us the bending jig dimensions. I will ask from a friend to Produce it for my personal use.
my dear friend
Greetings, Shota. I have no problem and will give you the dimensions for the jig. However, this jig can make capsquares only for the cannon size with a trunnion size of 1.4 mm~1.5 mm. For larger trunnion sizes, you will need another jig. I will post the sizes a bit later, today.
