IMHO do not. Do all full frames and then the cants.I'm trying to decide if it would be easier to install the cant frames first, before gluing in the full frames, or to glue the full frames first....
Any suggestions out there?
I did them first but ended up with lots of sanding to make them flow to the bollards.
Do the bollards/ full frames and you can adjust individual cants to get a nice sweep to the bow. Far easier to avoid unwanted jogs, etc., possible at mid frame curves depending on how the angled bottoms are trimmed to fit keel.
Keep bottom thickness as constant as you can, even if they are thick on the bottom/outside which will all be sanded down a lot to marry up to keel.
 I also started building the hawse pieces along with making X8 frames just for something else to do while glue is drying on the frames under construction.
