It has been a while since the last update, but i had a little set back, with the next futtocks to place, i got the same problem as with the first ones.
The side that is left open is quite reasonable, but at the other side i had some problems.
At the other side i had to place the futtocks one by one. Fit, correct and then place it, and clamp it to let it dry
At that moment, i was doubting myself, was i doing something the wrong way or what???
I checked everything that i was doing, and what did i use to do it, and after some communication with Matthias, the designer of the kit, it appears to be that the teeth of my comb are not exactly on the sice of the futtocks, they are slightly of, and my futtocks where also a somewhat thickker as they should be.
So i had to improvise a bit.
For those who wanted to buy this kit also, i still think it is an excellent kit, but don't rely on the comb alone, place the first futtocks temporarily between the floortimbers when placing the them on the keel. so you wil have a better placing of your first parts.
The other builders on modelbouwforum.nl did not have the problem as big as i had, but that was a bit of bad luck of my side i guess.
Anyway, i got all futtocks in and it looked very satisfying, altough i had to dive into my toolcabinet voor a clamp that i normally don't use for modelbuilding.
A giant clamp for these small futtocks
Now it is time to clean the remaining futtocks, and that wil take me a while again.
