Hmm. I wrote off the first curl as doable - now this second element has gotten my attention. You seem to have an untapped variety of skills available to you my friend! Bravo!
Good evening Herman. Wow that is brilliant- carving skills in your repertoire as well. Cheers GrantSome further work on the stem elements.
A slot has been milled/filed in which ornamentation will come. In front of that is a (narrow) space for the figurehead. On top of all this the next curved beam ending in a decorated curl. The inspiration for this curl came from the stem of the replica.
The elements are not glued yet.
wonderful carving![]()
Very nice carvings, Herrmann. These things are simply fascinating.
Wow and a double WOW! I am sure that lion is in within your scope of rapidly and ever-expanding capabilities, Herman. And please no kitty's head for the 7P. Only a South African lion will do her justice!
That’s a very good step, Herman. Making the drawing you made a imprint in your head for further visualization during the carving. Looking forwards to this carvings of yours.Thank you all for the positive comments.
Although I want to proceed my build by making the wales and gunports I could not let go the idea for designing the ornaments for the stem and stern beam and of course for the lion figurehead.
The ornamentation for the stern beam (the heigth approx. 5 mm.)
Ornamentation for the stem (the heigth goes from 4 to 6 mm.):
And the first drawings for the South African lion. I must say it is not an easy job to draw a convincing image of a lion (with crown) and this is only as seen from Ithe side. It certainly will take several more tries and a front view. I think that you must be able to draw the image of what you want to carve otherwise it will be much harder too make that carving.
Good afternoon Herman. Wow. I’m blown away at your carvings. I cannot carve and admire you guys who can achieve this. Cheers GrantWhile working on the wales I alternate this part of the build with some work on the ornaments. The carving work for the stern beam has been completed.
First I made a strip of wood to fit into the stern beam. That strip was glued onto a piece of paper that was glued onto a piece of wood to get a solid base for carving. Once finished it is easy to remove the carving from the wood base by means of a knife -the paper is then scraped form the carving.
The carvings for each side of the stern beam.
The palm gouge I used to make this carving (together with a file and finished with steel wool).
The end result of the carvings in the stern beam.
Later the beam and carvings will get the color ochre yellow. But for now they will be stored.
wonderful carving dear HermanWhile working on the wales I alternate this part of the build with some work on the ornaments. The carving work for the stern beam has been completed.
This is proof that in addition to being a model builder, you are also a gifted woodcarver. Just a big WOW, Herman.While working on the wales I alternate this part of the build with some work on the ornaments. The carving work for the stern beam has been completed.
