Very good work my friend - I like your "metal" works - we can see on the results, that it is really worth to do the additional work
In the past few days I have made galleon knees and other parts of the galleon. I made the galleon knee from two parts. The galleon knees have gaps / depressions on the outer edges. A routing machine would be ideal for this, but I don't have one. I helped myself with my milling machine: I clamped a small metal rod (shaft of a broken micro drill) in the vice. I will press the piece of wood against the metal rod to mill the timber. The cutter comes from above (it would come from below on a router) and you have to set the height of the milling head and the distance to the metal rod. Push the timber firmly against the metal rod and the milling head and joints can be created . The metal rod ensures that you can always remove the same width of the joint and never remove too much wood. Such a joint would not be possible with a file, carving knife or something. However, give care to your fingers, first try it on other wood pieces. Especially at the ends of a workpiece, you have to be very careful that the milling cutter does not pull the wood away. If necessary, do not mill the joint at the end, but file manually.
For the openings in the bow for the anchor ropes, I turned brass metal sleeves that go through the bow and have a larger diameter on the outer wall than the opening. The starting material is an 11mm brass rod, into which 8 mm steel drills are drilled on the lathes. A small ring on the front of the sleeve for the outside remains 11mm thick. The remaining length is tapered to 9 mm in diameter using the lathes. The inside of the sleeve then has a wall thickness of approx. 0.5 mm and is stable. I haven't browned the sleeve yet, maybe I'll leave it like that, then you can see better, they're made of metal.
Now I wish everyone a nice Christmas
View attachment 124820View attachment 124821View attachment 124826View attachment 124827View attachment 124828View attachment 124829View attachment 124830View attachment 124831View attachment 124832View attachment 124833View attachment 124835View attachment 124836View attachment 124837View attachment 124838View attachment 124843View attachment 124844View attachment 124845
Maybe you can show us your comment and clarify it more with one photo, what exactly you mean?I was looking at your model for the first time:
There is a serious error on the openings for the anchor ropes!
They must be parallel to the keel, not perpendicular to the side!
Ach soThe holes in the model are perpenticular to the surface. In the plan they are parallel to the keel.
The francois for example, shows the holes with a kink. I don´t know if every hawsehole has this detail in this form.
Now I'm reporting on the expansion of the two small rooms in the rear of the first canon deck. Of course, the two doors are special, which also open and approach hinges. The doors have a knob to open, too. For the grid windows in the doors, I ordered fine wire mats from Amazon, so finely you can't weave it yourself.
View attachment 197029View attachment 197030
I love hints but I don’t love critics every time for every detail, please stop that!
Joachim is doing here a good job, nevertheless nobody is perfect and also 99,9% of the models from us are not perfect.I think I expressed my thoughts in a polite way, I didn't want to be argumentative. Your model deserves more attention to detail!
If you prefer to make fun of you saying that everything is fine and that you did a wonderful job, happy you!
He is doing a beautiful job. Here are my thoughts on this. If I post a photo of my build and ask, what do you think? I want an honest constructive answer sort of like what Giampy gave, because I want to improve my modeling. So take a look at what you created and ask yourself... do I want to try and improve this, or am I fine with the way it is and I will use the advice on my next model. Your thoughts?Joachim is doing here a good job, nevertheless nobody is perfect and also 99,9% of the models from us are not perfect.
As we know, that you are working in your actual model in a smaller scale, it would be good, if you can show or explain how to reach better results.
As I know Joachim personally, he is open for any hint and tip, especially because it is the first scratch build model by Joachim after some finished kit models.
