• Beginning at 5:00AM PST (13:00 UTC) on Friday February 14th, all services in the Los Angeles, California, USA Data Center will be offline to perform a Data Center Migration. Due to the nature of this migration, we anticipate up to 24 hours of downtime to safely complete this work. Please be patient during this time and thank you for being a valuable member of our community.
french 64-gunner LE FLEURON in scale 1:48 by Joachim
The cannons must be fixed to the side walls. For this purpose, a ring is attached to a bolt and a hook to the left and right of the cannon. Both go through the inside of the side walls and are fixed on the outside with a round nut. The ring hangs on a bolt. The bolt is made from a square 3x3 mm brass rod: first, I turn the rod to 1mm diameter for a little more than the width of the side wall. I leave a 3x3 mm cube behind the 1 mm round rod and saw off the brass rod. Then I drill a 1mm hole in the cube. On the disc grinder, I flatten the material on both sides of the hole. Then I file the square end round and insert a ring. I solder the ring. Practically all of my machines are used for the small bolt.
Next I made the big servants for the main mast and foremast. These wooden blocks start in the floor of the first cannon deck and go up to the second cannon deck.
Milling out the slots for the brass rollers is challenging. I milled from both sides with a 1mm cutter because the cutter is too short. So that I can get the approximate position of the slot on the back, I drilled the wood block finely (0.8mm) through the top and bottom of a slot from the front.
8C65A88B-AC54-4D21-86A2-5DEDD44711D3.jpegD7E35097-25D7-4AE8-B163-CA90F0B0E542.jpegD9BB211A-8D63-44D7-8BD4-603083824A43.jpeg3CE7A874-0DBB-4846-BA97-18E300E610E7.jpegA1BF62C8-B9B5-4D7E-9BC7-F512D1E4C016.jpeg6AC26ED6-4A40-4B4F-BC5B-37DB853A09E0.jpegAD5643E1-D22F-401F-8FE0-F6D64CCD1C52.jpegD1388C82-D30E-4BEF-8BF4-4CDCB5939593.jpeg0A83AF4A-9DA9-49AC-94E8-34ED0B4BE3B1.jpegAB44C654-BBB5-4CA2-AAC4-9B5425572131.jpeg
144 single and double blocks for lashing the cannons have to be made. First I drilled the holes for the rope guide, then I mill flat slots in the wooden strips. Then I saw out the blocks and then I filed. Because of the sheer volume, you're busy at first But the prefabricated Krick parts don't convince me anymore in a direct comparison.
And here are a few more pictures of the main and foremast mast guide. Also not trivial to manufacture: around a thick rod (one end is then inserted into the lathe), beveled individual strips of approx. 4 can length are glued without a gap. The lathe is then used to turn the outside to the future scope. Then the inner opening must be turned. First drill down to the thickest drill on the lathe, then drill again with thick milling cutters until I was able to insert an inner chisel into the "drum".
18DD2DDE-9847-4A83-BA3E-4A06BFAE0FA0.jpeg9AAE91A6-51A4-4083-A6B7-84A972E4EBD4.jpegFDF2899B-437D-4417-9E67-E44D9D754911.jpegD6410D83-9E5F-484A-8664-5D084FC13229.jpegB89F54FB-4D7D-469D-8D7A-D53B3D1E0C4D.jpegE4C84DA5-EF36-4535-B942-42C9681A9DD9.jpeg4175E917-95F5-43B8-BAFA-ACAF8A250120.jpegD316ABC9-F40A-414C-9460-F7C403598718.jpeg
On the next pictures you can see the large capstan in front of the mainmast, which is in the first and second cannon deck. Three days of construction. First I turned a round rod from a thick square rod. Then I milled two octagons with the milling machine and a dividing head for the two capstans. A rib is placed on each of the 8 corners of the octagon. To do this, a corresponding notch must be milled on the back of the ribs. Now it gets even worse: the ribs thicken towards the bottom, and this has to be milled and filed again. Then the whole thing goes back on the lathe to bring the top part to the correct circumference. The whole thing then comes back into the dividing attachment on the milling machine to drill the holes for the capstan pegs. With a file they become square . Then the part comes back on the lathe and is finally made pretty. As you can see, a complex part that requires all machines.
6172ABA4-D4E7-4376-9BC7-9D260193D447.jpeg6A1F1AE1-4E96-45CF-84D7-E786D3CA81F0.jpegF55F73EC-A4D4-48B4-9924-DDC060FB3C87.jpeg460DD16A-A0A9-4B34-8526-A3D9611C29E3.jpeg5BA4CC2C-F29F-4F44-970C-165E44954E9A.jpegCF0EBF27-80E0-4D29-BBF2-4E8FF07D3B6A.jpeg78EE39D9-313D-4072-94A4-9BB2E63EA836.jpeg3068D1BA-D7B6-46C6-AB8B-4A905C4EB904.jpeg3515C300-4911-4577-A1F6-7289BAA78587.jpeg3F39BD6E-D6F2-4C51-AD6D-F4ED1400EB29.jpeg978B752C-4BB0-479D-93FF-32149DBB24D2.jpeg69957E83-5F5F-419F-A18F-A9D1891EC1EF.jpeg10DD5F94-60DC-4B61-8425-CBCE24D871B2.jpeg
Dear Joachim :)
I have been sitting and reading your blog for about an hour, and I must tell you that it has been a delightful experience to read and see your excellent building abilities especially in a very complex model.
The results you present are simply beautiful and make me continue to follow your work with great interest and curiosity.
Thank you! I have learned and I am sure I will learn a lot from youThumbsup
# 241 10/01/2020 7:57 PM avatar Joachim Last month I was busy installing the fore and main mast and bowsprit provisionally. They fit . Then one half of the deck is planked and painted with decolorized shellac. Then I went to work on the gun hatches. That's a lot of work! Not only producing 24 hatches, but also the fittings / hinges for them. These metal works alone take 2-3 weeks.
Dear Joachim
you are doing excellent work, Thumbsup Thumbsup
Which creates exceptional results in beauty
Very good work and progress . she is getting a beauty :cool:
Many Thanks for sharing with us
Are the hinges self made? or did you use some photo etched parts.....?
This is purely amazing. I am speechless as the amount of work and details. Breathtaking. Exceptional.
Thank you for following
The first cannon hatches are now attached and the hinges allow to open and close them without any problems. That makes me happy because it was a lot of work to build the many parts of a hinge.
E02BE25C-B501-4960-A335-DA8C3E7E7C2F.jpeg773BE920-DCAB-4845-A3DB-D22CF297D2CD.jpegFCF1AE28-BFA7-4AC3-8541-627F9E8AA8A4.jpeg
The sailors also have to eat. That's why I created the oven :). The actual stone oven is made with plaster: I made a negative form of wood for the cavity of the oven. I tried to build the stone oven with selfmade plaster bricks. But it didn't work with the scale. The structure was too fragile and when it was released from the negative mold it broke. So I pressed a lump of plaster around the negative wooden form and let it dry on a radiator. Then the exit from the negative form goes quite well. The bottom of the oven is then covered with burnished brass foil. Now the sailors have something to bite.
51E51293-E0DA-4FF1-8252-0907C0FB045F.jpeg61D6F6D3-AB6C-43DA-8839-545C49C07E69.jpeg6AD9CC10-21F5-4E94-9FB9-24D390E4D5AE.jpeg185F0A55-A558-4C7D-B83D-37976D9B08F6.jpeg3CD4D4A4-802B-43AB-BBEE-DECE0F841D84.jpeg2F6E6025-DC75-415D-B737-64505807F93D.jpegE6019E22-BADD-47EA-8FA1-7B0DC8373461.jpeg9CA86393-92A4-4D85-B8B8-AD26C1B5F7EC.jpegC038E0F7-6844-474B-8E32-167A671178C7.jpeg
View attachment 187466View attachment 187467View attachment 187468View attachment 187469View attachment 187470View attachment 187471View attachment 187472View attachment 187473View attachment 187474
Great detail my friend - I am getting hungry and would like to eat a fresh french bread
There are many fastening rings for the cannons on the planks. I made the pen and ring myself. I could also have taken finished parts of Krick, but I didn't like it (rings and pins are thinner from Krick, that looks less massive).
5C9FA600-6851-4CD2-B371-337AB255F7C6.jpeg773538BB-FC3F-4D0A-9231-2A06354B92E7.jpegB73828B2-CF79-41E3-9717-587932654D7B.jpegE916AAB7-7F18-4D69-B3DC-4249DBCDFE88.jpegDB6EB64B-0180-4F58-AC5C-D377642F02D8.jpeg13470CE0-1F00-4C77-A7A9-A9779E21C7E9.jpeg220FB71D-DEBB-4519-8CB7-4A291DD95233.jpeg
