Hallo Donnie,Hello Uwe,
I do not want to interrupt Brian's answer, but I did find out some info that I share on POST #114. I am sure that Brian will like to have the opportunity to respond - sorry Brian if I answer too soon for you. Please elaborate if you wish.
thanks for the hint, but the principles are clear for me. I asked where would be the area of the frames, looking at the framing of Brians model, and not on a single frame
Yes, I understood, that you will do it different than prepared by CAF - with a saw you can cut where ever you want...... but where is the "line" if you would follow the CAF kit design. Is the red line appr. correct in my photo? I would like to get a confirmation on my thoughts.Hi Uwe and Donnie,
I was considering building the frames without a separation, then cutting through them with a Dremel diamond disc.
Not sure whether it will work, but previous experience has been good using this diamond disc.
.View attachment 292557
I am interested in this, because I am thinking about trying this solution on my model....
