- Jan 9, 2020
Hello Hans. I understand completely that the idea is to use the part that was cut-out as the lid again. That would obviously ensure that the color, structure and grain of the wood, are all identical. However - that is the theory - then you get Heinrich and real life. I will be able to get the gunports cut-out and perfectly square them (no problem), but the chances of that little cut-out piece surviving the process intact, are slim!The fact was that the cut-out part of the gun port was used again to make the lid - so not even the colour did match, but the structure and grain of the wood as well.
Most probably the canons on the original ship were never used, as they sailed to areas where no enemies where to be expected.
You could go for the situation where most of the ports are closed, and only a few open with a canon sticking out.
If you mount it in a storing position you will most probably don't see anything of it.
I can give it my best shot though!You making a very valid point of not much being visible of the cannon and carriage in the stored position.
Thank you very much for your input Hans. We are definitely having a dominant line of thought it seems.
