Okiedokie
I promised an update on today's proceedings (not yet finished - there is still time for one plank to be glued
) and here it is.
One thing I neglected to mention is how ingeniously the inner planking strengthens the bulwarks from midships to stern. Just to recap, the inner planking is indicated by the area marked in red.
Now if we look from the outside, this is the picture.
First off, notice the sequence of how the upper bulwarks are planked: A 6mm strip, then a 2mm strip and finally two 6mm planks again. But ... because the bulwark runs in a curve and because the inner planking is done with 4mm strips, it means that two of the planks overlap the joints of the previously planked strakes, adding great rigidity. The two solid, red lines indicate where the overlaps occur. However, this is not the end of the bracing - not even close. Hopefully I will be able to show you more bracing tomorrow night.
So, before I could do anything today, I had to complete the deck planking as that had to be done before the inner planking could take place and before the inner rails could be installed.
Deck planking has been completed and the inner rails on the port side have been installed.
And
@RDN1954 Johan, just for you - note that the bowsprit opening has been "opened". Looking at the deck I have immediately decided against any staining or any type of finish that would change the color of the deck. That means that I will follow
@Dean62 Dean's advice and apply a Polyurethane Varnish only to the deck.
Of course, finding a suitable product that I can trust is a different story altogether. In the end it seemed that my best bet would be Dulux Polyurethane Varnish with a Matte finish (obviously I don't want anything shiny on the deck). The added advantage of the poly is also that I will be able to glue the various deck items later without hassle. But - seeing that it is almost Spring Festival in China, all online shopping networks like Taobao and Jidong, have suspended their delivery services until after the 10th of February.
Nothing is ever straightforward.
With the deck planking thus completed, I could start the inner planking of the port side bulwarks.
Happy shipbuilding until tomorrow everyone!
