- Apr 20, 2020
good evening dear friends
Tonight I continued to create the gun powder room, while today I created the door of the upper entrance to the room, the frame I already created last night.
I measured the inside of the frame which was 15.16 mm wide x 14.15 mm long. I cut 3 pear wood boards 5mm wide x 14mm long. After sanding the boards, I created a slight slope in the longitudinal lines, to create a deck effect in the connection areas.
In the inner part, I reinforced the door structure with 3 panels that will create a z shape.
After the glue dried, I gently sanded the 3 sides of the door, to give a nice finish. The area of the connection to the hinges is not shaved.
Later I made hinges for the door from copper that underwent a light oxidation process. I connected the door with the hinges to the frame and later I also added a relatively simple locking mechanism.
I am attaching pictures of the result.
Thanks to all the friends for the likes, smiles and supportive compliments, it's very encouraging. good night
