HMS ALERT 1777 cutter POF by shota70 [COMPLETED BUILD]
HI Shote.
Nice to see your started with the deck beams.
Shouldn't you swap both outer 2 beams? See my photo below. Because the 2x3 intermediate beams (green lines) will not fit.
After switching, on both outside comes 2x2 beams.
Good eyes - you are right- the two carlings are reversed
Hello dear friends
Today I sat down to work on the model, first I went to take care of the mistake I made a few days ago with two carlings (2 & 5) directions, and which thanks to Peter's vigilance the mistake was corrected today.
Later, I looked at the drawings and noticed that there is a difference in the drawing: in blue, as well as in the brochure, you can see parts EL54-EL57 However, in the plates of the parts - the plate is marked DL. Do I understand correctly?
Another question:
Do I cut the thin width beams connecting the carlings from this board?
I would appreciate your assistance as soon as possible
Good evening friends
As you have understood there is a mistake in the registration of the parts instead of EL it is DL.
This is the intermediate result in the construction of the front deck that touches the bow.
I wish you all a pleasant and enjoyable weekend
20230310_153855.jpg20230310_160513.jpg20230310_165312.jpg20230310_165317.jpg20230310_183248.jpg20230310_183250.jpg20230310_183259.jpg
Hi Shota your Alert is growing and growing. Another nice detail added, wonderful work my friend.
thank you very much my dear friend for your kind words, compliments and encouragement .I appreciate it very much :)
Good afternoon dear friends
Today I finished the front part of the deck that touches the bow/keel.
The work required quite a few adjustments to achieve optimal accuracy. I'm satisfied from the result. The first two pictures show the deck after applying clear teak oil.
In the coming days I will focus on the preparation and construction of the remaining rooms and warehouses on the lower deck.
May we continue to enjoy life, our family and our hobby :) :D
Very nice work Shota! Maybe you could patch that little piece of missing wood on the carling??? Then it would be perfect!
thanks my dear friend :D
can you show me Where exactly do you recommend I place these parts, drawing/pointing to the pictures would help me a lotExclamation-Mark:)
I’m on holiday so I don’t have the ability to draw on the image (no computer). In the image above there are four vertical pieces. On the second one from the left it seems the part is chipped on the lower left corner. Or perhaps the part is supposed to be that way? You are doing such nice work I just thought I should mention it in case it is something to be fixed.
Paul you eagle eye ;) . I wish you a nice holiday and lots of rest.
אני בחופשה אז אין לי את היכולת לצייר על
My assumption is that a column has to pass there. Not familiar with the build, but that seems the logical answer.
התמונה (ללא מחשב). בתמונה למעלה יש ארבעה חלקים אנכיים. בחלק השני משמאל נראה שהחלק סדוק בפינה השמאלית התחתונה. או שאולי החלק אמור להיות ככה? אתה עושה עבודה כל כך יפה שפשוט חשבתי שאני צריך להזכיר את זה למקרה שזה משהו שצריך לתקן.
Dear Friends
Thanks for your attention, but I would like to emphasize that this carling came in this configuration - thinner at the end.
I will take a photo for you tomorrow and a deficit can be seen in favor of another part that is supposed to be completed/entered
