Hi Paul. Luckily l don't have to do that. With this kit the deck beams are made of 3 sections. The main beam which is made from 5mm x 4mm pearwood and glued to that, font and back, is a 1mm piece with the notches formed for the carlings
Yes that's right. The 4mm carlings are cut to fit into the notches on the beams, as on the real ship but to cut notches into the carlings and knees to accommodate the ledges as depicted on the plans would be next to impossible for me to do with any degree of accuracy so a tight butt joint is good enough for me. You have to look close to see it anywa
