My congratulations of reaching this working step - for me, although not finished, already a beautiful model
and, of course, make sure you fit the capstan before close off the upper deck - great work again. Ive just built my capstan thought that middle white wood bit was the spindle but like you use a dowelThe capstan is now made up, painted and installed into the hull
trying to fit the rear most hanging knee on the upper deck - i think it is mounted above like the rear lower kneesl have at last trimmed the frames of the hawse pieces to their correct heights and added the knightshead (l think that's what it's called) to the bow, completing that part of the build in readiness to take the hull from the cradle to fit the rudder. l think it looks a lot better at the front now
very helpful keef thanksl have at last trimmed the frames of the hawse pieces to their correct heights and added the knightshead (l think that's what it's called) to the bow, completing that part of the build in readiness to take the hull from the cradle to fit the rudder. l think it looks a lot better at the front now
It's been a busy week and today is the day Blandford left her cradle for a new, permanent, support which she fits into perfectly. We can now see the true shape of her hull and l can even fit the rudder without having to take her out, so now l can get on and finish the upper deck once the rudder is fitted.
i am pretty certain there is a filler that goes between the bow piecs nd the 1st frameIt's been a busy week and today is the day Blandford left her cradle for a new, permanent, support which she fits into perfectly. We can now see the true shape of her hull and l can even fit the rudder without having to take her out, so now l can get on and finish the upper deck once the rudder is fitted.
have you worked out what the solid piece of wood between 6 and 7 with a hole in are for very strange doent "look" right on minel have gone as far as l can with the upper deck beams and timbers for the moment, as l now have to work on the rudder assembly, while there is still room for access. l have given the upper deck 2 coats of Xylandecor wood preservative. The sanded deck woodwork looked quite white and it took your eye away from everything below, but now it is the same colour as the rest of the model everything has settled down so to speak and it is much easier to view the lower deck work. There is no mention of the rudder assembly in the instruction manual, only a rough diagram showing the numbered parts (6 in all), so it's difficult to find the parts that make up the rudder from the remaining sheets. Once assembled l have compared it with the 'Anatomy of the Ship' and it is a perfect replica. The 'iron work' l made from cartridge paper, cut into 2 mm strips and coated with watered down white wood glue to give it a bit of strength. Once fitted a coat of semi-gloss acrylic varnish was applied to seal it. l don't think there are parts supplied for the tiller which goes between the decks, so will have to scratch build that part.
The solid piece with the hole between beams 6 and 7 is the support for the sea mortar. You have the choice to either fit the piece and make up the mortar supplied or leave it open to make up and fit a grating. The kit supplies an extra one if you choose the grating instead of the mortar. Obviously if your hatch openings are not made square you are going to have problems fitting the gratings. l put a small amount of glue behind the mast partners before taking them out of the board to keep the tiny pieces together so they did not fall to bits. Not going to be easy now, if yours have dropped out. Once they are made up and framed by the carlings they are finehave you worked out what the solid piece of wood between 6 and 7 with a hole in are for very strange doent "look" right on mine
The Wang appears to have planked it with a hole
My little rectangle bits on the mast supports have dropped out - not sure which is correct
hello Keef, help needed! where did you get the positions for deck clamps and inner strakes? i cannot work it out !Deck clamps fitted and inner strakes in the process of fitting. 3 1/2 weeks work but not a lot to show for it. l had to improvise as l don't have clamps deep enough to reach the lower planks and as you can see the curves are pretty tight so the timbers have to be held securely while the glue dries. l came up with this idea using hair clips, bent to fit and it works surprisingly well
Hi Lezzer. Have seen your question. Will get back to you in a few days. Tested positive for covid on Saturday and feeling a bit out out of it at the moment. Sorry for the inconveniencehello Keef, help needed! where did you get the positions for deck clamps and inner strakes? i cannot work it out !
Praying for a full and speedy recovery Keef.Hi Lezzer. Have seen your question. Will get back to you in a few days. Tested positive for covid on Saturday and feeling a bit out out of it at the moment. Sorry for the inconvenience
no problem Keef, get well soon.Hi Lezzer. Have seen your question. Will get back to you in a few days. Tested positive for covid on Saturday and feeling a bit out out of it at the moment. Sorry for the inconvenience
Thinking about you Keef, get well soon.Hi Lezzer. Have seen your question. Will get back to you in a few days. Tested positive for covid on Saturday and feeling a bit out out of it at the moment. Sorry for the inconvenience
Get well soon, Keef!Hi Lezzer. Have seen your question. Will get back to you in a few days. Tested positive for covid on Saturday and feeling a bit out out of it at the moment. Sorry for the inconvenience
Thank you Paul. That's really kind of youPraying for a full and speedy recovery Keef.
