- Jan 10, 2022
Thanks Uwe.Very good progress - and it is looking very good![]()
Thanks TonyLooking good buddy. Best of luck with the medical issues !
Looks great, and a much better way of putting it together. Hopefully you've checked the framing above it for fit as well, although you can modify the top of the walls if required. Good luck with the fit - looking forward to seeing it.Aft platform decks and cabins are now complete. l shall attempt to place the whole assembly into position and see how it fits . . .
Good afternoon Keith, looks wonderful and a clever way of doing it. I would never get the measurements precise enough to fit in the hull. I hope it fits all good. Cheers GrantAft platform decks and cabins are now complete. l shall attempt to place the whole assembly into position and see how it fits . . .
Thanks mate. l don't know if l have yetGood afternoon Keith, looks wonderful and a clever way of doing it. I would never get the measurements precise enough to fit in the hull. I hope it fits all good. Cheers Grant
Thank you Paul. Brave, or just plain crazy?Superb progress my friend! And a very brave approach to the construction!
Thank you Daniel. Really appreciate your commentI really like your modular approach to the internals on this build. I bet everything will fit in with a minimum of adjustments.
I am with you Grant.I would never get the measurements precise enough to fit in the hull
Thanks Uwe. You are very correct. That last bulkhead does not fit at all well to the shape of the hull. Fore and aft position is correct, aligning with the front of rib 47 and also the height is right with the other components and it sits on the keelson as it should but the shape is totally wrong. Will look into the problemInteresting and different way of assembling (compared to my way) - different but very good -> Bravo!
I am more the step by step installer
Please check the last bulkhead - it is maybe not fitting so good to the form of the hull - but iut depends how much will be later visible
