Hello Paul, there is an option to build it with full frames or the split frame scenario.
Hi @Bryian,
Does this kit require the split hull? It looks like the frames and stem/sternpost are pre-sectioned? Or maybe I'm missing something? Thanks much!
So, if I understand you both - the kit comes with the frames (etc.) already cut into upper and lower portions - but the builder can choose to glue them together keeping the hull in one piece? Thanks for dialoging with me on this - I am considering several different POF kits for my next build and want to understand more about this particular (crazy impressive) kit...
Hello, Mon Amie. The below image should give you an idea of how the hull is split should you choose to accept this method of assembly.So, if I understand you both - the kit comes with the frames (etc.) already cut into upper and lower portions - but the builder can choose to glue them together keeping the hull in one piece? Thanks for dialoging with me on this - I am considering several different POF kits for my next build and want to understand more about this particular (crazy impressive) kit...
and it is not only a "simple cut" of the frames - there are the futtocks separated from the top timbers. Like the real ship the separation of the upper part is produced by the separation of the frame elementsSo, if I understand you both - the kit comes with the frames (etc.) already cut into upper and lower portions - but the builder can choose to glue them together keeping the hull in one piece? Thanks for dialoging with me on this - I am considering several different POF kits for my next build and want to understand more about this particular (crazy impressive) kit...
When you start once with POF - maybe you will never want to make a POB anymore.Thank you gentlemen. I get it now. The hull splits at natural locations in the framing. Brilliant engineering that will require some very carefully thought through 'bracing' so the whole thing doesn't crumble into a heap of kindling. This one might be outside of my skill set for a first POF build.
Sorry for the off-topic Bryian.
I can underline these words completely.As Uwek said, you will be more than capable of doing this ship.
These POF kits made by CAF and others Chinese builders are easier to build than a few of the POB that you find around. Your Vasa is an example of a difficult POB and you are doing it fantastically well.
Nevertheless, I had the same thoughts as you. I was really afraid of these POF kits. So I started with a cheap one and very pretty to me "the Marmara Trade Boat". I succeed on its built. Then I jumped to the Pegasus. That kit almost do not have any instructions, did it by pictures of other modelers and plans from the Utrecht. And all went well. You saw my builts. My skills, compared with yours, are of a kindergarten kid. So there is absolutely no doubt that you will succeed on any of these POF.
Now, decide what would be the POF kit ship that you would like to see for years to come in your house, and go for it.
Cheers !!
Daniel
BTW: on the built link I posted for you, you have pictures (on page 1) on how the ribs are kept together during the construction of this particular POF from CAF.
Thank you Uwe and Daniel. Yes, I will make my next build POF. I actually like the woodworking part most of all and I think I will have many hours of enjoyment if I select the right kit. I thank you both for the counsel (and again, Bryian, my apologies for taking your build report down this rabbit hole).I can underline these words completely.
Maybe to add one more sentence:
Making frames and the structure with beams knees etc. for a POF is according my opinion more wood working and maybe more "shipwright work" than with a POB.
And enjoy the hundreds of hours with the pure working with wood - so invest in a model with high quality wood - you will enjoy every hour
and it is a very good way to come into scratch POF - building
So Paul, order this or such a kit - you will enjoy the work on such a model like the Granado
This is not Brian’s log,actually Caf’s development tooixThank you Uwe and Daniel. Yes, I will make my next build POF. I actually like the woodworking part most of all and I think I will have many hours of enjoyment if I select the right kit. I thank you both for the counsel (and again, Bryian, my apologies for taking your build report down this rabbit hole).
Oops! Thanks Zoltan. Turns out I was 'on topic' after all!This is not Brian’s log,actually Caf’s development tooix
