It's really quite beautiful!
It is a spar with a roller or sheave at its end, used for fishing the anchor or to be precise an anchors 'fluke' without damaging the hull.This is something new to me, what is/are the purposes of the fish david?
(Archive.org), refers to the process of raising and securing it to the ship. It is hoisted vertically at the cathead by a cat-tackle (catting), and the flukes are turned with a fish-tackle to secure them over the gunwhale (fishing) and to prevent damage to the ship as the anchor is stowed.
Just beautiful! Great job on those frames and You're right. This wood is georgeous
WitajOne of the last missing parts on the section model are the two guns which should be mounted on the planked side of the model
Comparing the gun muzzle and the carriage (incl. brass parts) of the kit with the given drawings in the Anatomy book are showing us, that the armamant is very well reflected
I have only problems with Goodwins drawing of the gun tackles, which I do not believe
1) Goodwin shows the ringbolts and eyebolts for the tackle and breeching very low, lower than the gunports arround the height of the wheels. In my opinion they should be higher left and right of the gunports, so the tackle will not have any contact with the wheels (red arrows). By a recoil, also if it would be for a 4pdr relartively small the front wheel would roll over the tackle, so the tackle had to be removed before firing.
2) w widoku z góry widać, że natylnik jest bardziej na zewnątrz niż sprzęt - nigdy tak nie widziałem, więc myślę, że powinny być pionowe w tej samej osi i nie przesunięte (zielona strzałka)
3) Nie wiem, czy te małe działa z zaledwie 4-funtowym pyskiem rzeczywiście miały upadek sprzętu poprzecznego (nr 2) - zwłaszcza, że za działem nie ma miejsca z powodu dołu moździerzowego. Jestem pewien, że były one w całości poruszane rękami pchającymi wózek za pomocą ramion dźwigni
Mam nadzieję, że opublikujesz kilka komentarzy i opinii na ten temat.......
po raz pierwszy Granado jest uzbrojony w 4-funtowe działa
a teraz też poczerniały - wykończone prace w drewnie na wagonach
a także dodał prace metalowe na wagonach
tu widać, że nie było miejsca na upadki trawersu
Wielkie dzięki za zainteresowanie ......
