HMS GRANADO - full hull - POF kit by CAF in 1:48 - by Uwe
I did not understand the discussion fully.
The CAF model and also Uwe are showing the typical English method of the deck frameing beams, carlings and ledges. The AOTS also shows beamarms. and I think that Uwe will also do by the next deck (In the original drawings I don't find a hint but it is always a question if they were omitted because this detail was standard practice).
The model has in the construction a simplification. The carlings and the beams have the same thickness which was not common practice. On the finished model this is not really visible by the platform.
Hello, I think with this image the various doubts we have are completely resolved
The next working step - installation of the carlings with 2*2mm stripes
and the dry fit inside the hull
step by step - Laboriously the squirrel lives
The next are the laying knees and the carlings attached to the knees
Many Thanks for your interest .... to be continued
Inbetween the discussion: a very nice and precise piece of deck construction, Uwe. Afterall we (almost) can’t see what kind of fitting is made. But that’s for more builds: we know!
Hi Pietro, I have never allowed myself to criticize Uwek's work for the beautiful work he is doing but, I notice that my observations are annoying, I close here any comments in the Forum, I limit myself only to observing, greetings
In order now to clarify one final information about the kit.
This is realy a simplification like Christian mentioned in his post, and was prepared by CAF only in the lower deck area aft (red line),
which will be once more covered by a next deck.
So usually absolutely not visible from the top.
The normal deck beams (green marked area) are different
But stay tuned ......
In order to come back to the building log, I would like to show further photos of this mentioned after cabin deck structure
with lodging / laying knees
some closer look of the knees with copper "bolting" and carlings and ledges
one side prepared (the deck structure is still only dry fitted in the hull)
Many Thanks for your interest in my building log, many thanks for the discussion and comments ..... to be continued ....
and now I can show you also the final solution I prepared to solve the "problem" with the carlings have / had the same height like the small beams of this deck
The following is howing the deck structure bottom side - I have sanded the carlings down by 0,5 to 1mm. just so much, that there is a small height difference at the connecting to the beams - but nobody will see the model from this side
usually it would be this perspective view from the top down
- if you look close you can see barely this small step - finaly this view has to be through the main deck structure, so also not really visible
But as you know, I plan to cut the hull on the waterline and present the upper part of the ship somehow floatinmg over the hull in app. 20cm -> so also this viw could be possible, if someone will go on his knees and look upwards
somehow like this view
even then some small shadows will show, that the carlings are "laying in recesses in the beams
Easy solution with finaly acceptable result (in my opinion)
Many Thanks for your interest .... to be continued .....
Dear Uwek
sophisticated solution Exclamation-MarkOkay:)
looks great from the top
Lovely work Uwe,
Cheers,
Stephen.
Nice solution, Uwe.
Is it correct, that you will install the ensemble later under the planks in the space area?
Correct
But I think, that I will install and fix it before I will cut horizontal - it will help additional for the stabilizing of the upper "space area"
and btw to all who made kind comments - many thanks
and also for all the likes received -> much appreciated
The next to be prepared are the real deck beams, carlings, lodginging knees etc.
So I removed all the temporary internal stuff like the mortar beds etc. and concentrated of this deck structure
so first some impression about the elements - everything only dry fitted
at the bow
one frame for the mortar
the midship section with the heavy lodging knees
as mentioned - in moment only some impressions .... to be continued .....
and mayn thanks for your interest :cool:
step by step - still everything dry fitted and not glued - aim is that all element are getting the more or less correct fit
btw this is the original photo showing the obligatory and usual mess on my table
the recess on the lodging knees are still not prepared - important is here a parallel orientation of the carlings and ledges
all carlings are prepared
some of the carlings are still too high, so the recesses have to be overworked
the recesses for the ledges have to be prepared by fine chisels (see on the left one reccess in original round shape caused by the normal cnc machine - a time consuming work
still a lot of work in front of me ..... many thanks for your interest
