I'm amazed that you can get it to stay together with no glue. And you bench is immaculate compared to mine.
Very impressive Uwe,step by step - still everything dry fitted and not glued - aim is that all element are getting the more or less correct fit
btw this is the original photo showing the obligatory and usual mess on my table
the recess on the lodging knees are still not prepared - important is here a parallel orientation of the carlings and ledges
all carlings are prepared
some of the carlings are still too high, so the recesses have to be overworked
the recesses for the ledges have to be prepared by fine chisels (see on the left one reccess in original round shape caused by the normal cnc machine - a time consuming work
still a lot of work in front of me ..... many thanks for your interest
That's a lot of parts Uwe,Hallo friends,
many many thanks for all your kind words and comments - and also for all the likes received - it is a great community here in SOS
the deck structure works is like making the frames or hull planking - it seems, that it is never ending
Today some (maybe boring) photos of the ongoing beams, carlings, ledges, lodging knees work .....
at the end there will be around 300 wooden parts installed with appr. 300 copper "bolts" inserted
Many Thanks for your interest ...... to be continued ....
The result of that are the same boring photos again. But then with glue. I can't wait to see the difference of thatThe next working step will be the permanent installation
