Any special glue for the teak, Zoli?Hello guys, I have started the preparation for deck planking, thickness 2 mm and the width is 6 mm , wood type is teak.Noting glued in just cutting timbers to size.
Nope, Pva and CaAny special glue for the teak, Zoli?
Janos
Look at the margin planks, I used Pva and CA , also look at my Santa Mara , deck planking all teak , never had issuesSurprising. Cabinetmakers say that PVA does not work with teak because of the high oil content. I also had a bad experience once with an old shipmodel which I had to restore. PVA did not work, I had to use epoxy.
Janos
Thank you Lawrence,I did not use any jig or mill,I cut the margin planks with a scroll saw, left some meat on them than used my files to shape scarf joints to match each other. For caulking, I am using regular black construction paper.Hello Zolly, just catching up on your build log. Your decking sure is looking great, well done. I have a couple of questions that is if you do not mind and they are. How are you cutting your scarf joints, on a jig or in a mill? What type of paper are you using for the caulk lines, I tried this many years ago with very little success? Thanks.
Regards Lawrence
YesHello Zoly, will you use the black paper between the planks to imitate caulking?
Thanks Brian!!The ship model is looking really great Zoly. Keep up the good work.
I agree with Mike, you will be rewarded at the end!So the planking/caulking begun ,this paper caulking is very delicate and slow process.
I do not know exactly,must be between 0.250 - 0.500 mm, school construction paperHello Zoly. What is the thickness of your black paper? Looks really good. I can only imagine how the deck will look under oil!
