HMS Victory by Y.T.- Mamoli - 1:90 scale
I am amazed I was able to make it right first time
Excellent looking rope!!!! There are experts on SoS that can tell you all kinds of things about rope. Different directions of twist for different sizes of rigging... just mind boggling!!!! Almost a whole hobby in itself..
Hi. I got my first ever mini rope made on Domanoff machine. It is 0.38 mm diameter. I am amazed I was able to make it right first time with no previous experience. Just was following Domanoff’s instructions. I am happy .
View attachment 161839View attachment 161840
The workload starts when you have to make cable laid anchor ropes. But making your own is giving great fulfilment.
That looks so much better. I'm working on same and wondering why do they supply garbage with these kits. Plus missing parts. I have a ZHL kit which is next, and it's the only kit I've ever rec'd that actually gave a full inventory.
Here I will show you how I make the window frames. I finished 6. Now I have to make remaining 39 frames. Quite a task!
Sequence:
1) cutting out plenty of little sticks which will become my future vertical and horizontal window frame members. These are cut of 0.5 mm thick oak veneer.
2) making carton templates to fit exactly into existing windows. There is no one window same size as the other one so each template is unique. I number them so I know which fits where after I take them out.
3) Using cardboard templates trace their outline on piece of paper.
4) draw outline of all future frame upright and horizontal members
5) I mark up with pen and cut our tiny notches on every frame member so they are assembled together same way ship grating pieces are getting made. For making notches quickly I made up a quick tool made of standard one side blade. Blade was annealed with torch, heated red hot and quenched into water, then tempered in my baking oven.
6) then every member is getting glued with PVA glue where it belongs on the paper. Whole frame is getting wetted with diluted PVA glue.
Rest is just cutting off the ends, cleaning up, grinding to proper thickness, ensure it fits into window opening, painting yellow and gluing into the window opening.
CF2EF0D1-9B8C-4669-8D80-37FF722C2998.jpeg8F146FE8-D552-44D7-BCD7-D924E9B0CEB5.jpeg245D3190-91AF-43A5-868E-AF76D94A57AA.jpeg7E9B4E4D-3EB3-4FA5-BEC8-11583A0143E3.jpegE81F922A-1638-440F-8284-086847C69BCF.jpeg1BBC6F83-0B9B-4ACC-97DB-00941DC79356.jpeg
Look at newly added window frames assembly instructions above. I take pictures and upload them to this forum with my I-Phone. The comments however I am adding through my normal computer as it is much more convenient. So my instructions are getting added later after pictures were inserted through the I-Phone. This is a craziness with current technology.
YT, hi, I'm working on the same model. Maybe you can help me with something. Going from Pg 8 to pg 9 and plan B. the parts numbers jump from 238 to 300. I'm stumped here and dont know what I'm missing. I understand the build process, but where are the parts? Maybe I'm being blind here and don't know. I can account for a few of those, such as lanterns, string and chain. But that still leaves a great deal unaccounted for, thnks, Ken
Hi Ken. On pages 8, 9, Table A and Table B I found bills of materials 222-239, 317-381, 240-250, 300-387 respectively. Part numbers 251 to 299 are missing entirely. I am just guessing this was done on purpose in order to be able to add some parts in future versions of this model which had never happened.
View attachment 177971View attachment 177972
Thank you, YT. I'm just going to pick up with Plan B, #300 and just muddle along, where it should, hopefully, fall into place.
