Question is not addressed to me but let me answer. On my model I used existing current photographs of the Victory hull as a reference. Sometimes I got out of this control and was using my imagination a little bit.how you determined the width of the black and yellow stripes on the hull.
Crosstrees are lying flat on topmast cheeks or hounds. Trestletrees are lying on top of crosstrees making a very sturdy construction. This was held down by shrouds (port and starboard). All the crosstrees were fitted with wooden bolsters at the masthead, rounded off on the outside edges to prevent the shrouds from chafing on the trestletrees.This is how it looks like taken apart. No glue.
Thanks. That's how I did it on my full model. Working on cross-section now....Question is not addressed to me but let me answer. On my model I used existing current photographs of the Victory hull as a reference. Sometimes I got out of this control and was using my imagination a little bit.
Hi YT,Remaining free few hours of this week end I spent making fids and rectangular holes in masts. Broke two drill bits making holes on the fid ends. It appeared drilling on brass breaks bits in no time unless you secure a piece in vise and apply some lubricant. I applied water.
Great tip. I learn something new and useful tome every day here!Hi YT,
Drilling Brass, the drill bit is best to have a negative rake angle or it will grab when the drill breaks through, this can be done by hand using a fine stone to just break the cutting edge.
Cheers,
Stephen.
Wow, BravoFinally I think I am done with ALL masts and spars. Here is what was done.
My first wooden ship kit back in 1983 was Mamoli's 'Blue Shadow', which, as an introduction to wooden ships, worked out very good for me, despite not finishing her until 2018! I've part built the Mamoli/Dusak Golden Hind, which I've found let down by the paper printed decor strips, I've not used these, instead I painted them on to pre-shaped veneer, then stuck them to the hull.Dusek resurrected the brand with some important improvements, but the whole series of kits really needs to be taken back to the start, redesigned, updated and reengineered. The metal castings need to be remodeled and new molds made, instructions rewritten and put into some reasonably logical, easy to follow order, and especially their approach to hull planking totally overhauled. A novice plunging into one of their kits is in for a rude awakening, and perhaps a life altering experience, possibly being disabused of the notion of ever trying to build a wood ship model from a kit ever again! I speak from personal experience. But perhaps being a glutton for punishment, I am now on my third Mamoli build. A word to the wise: Mamoli kits are for experienced kit bashers and/or scratch builders.
Pete
Therefore, after 40hrs you should have the 600 required!Took me about an hour to make these 16 blocks.
