I would be glad answering any questions regarding how I did all this.
Good morning Y.T. Brilliant ….wow!!Finally I think I am done with ALL masts and spars. Here is what was done.
Hi, etubino. Believe it or not I did this with with my eyes, ruler and pencil. I marked 0, 90, 180, 270 degrees spots. Then by eye the spots equidistant from marked ones. Then using same strategy did them all. Did necessary corrections when my eye told me that something is not right.how you came to such an exact way to make this tiny perforazon so good equispaced and aligned?
Beautiful work on the masts and spars Y.T.Our friend Johann has the same problem and has come up with a solution, maybe it would be a possibility for you too. Here is the link to his article.
Post in thread 'La Créole 1827 by archjofo - Scale 1/48 - French corvette'
https://shipsofscale.com/sosforums/threads/la-créole-1827-by-archjofo-scale-1-48-french-corvette.7643/post-336472
Great kit bashing! I rest my case!My first wooden ship kit back in 1983 was Mamoli's 'Blue Shadow', which, as an introduction to wooden ships, worked out very good for me, despite not finishing her until 2018! I've part built the Mamoli/Dusak Golden Hind, which I've found let down by the paper printed decor strips, I've not used these, instead I painted them on to pre-shaped veneer, then stuck them to the hull.
I agree totally with Tobias, a display case is a great idea, something you will probably need any way.
Cheers,
Stephen
Oh. I machined out a slot for the sheave in the mast. Then I machined a sheave. Then I inserted the sheave in the slot with some glue on the sides. The sheave, of course, does not rotate. It is just a dummy.How did you mount the sheaves in the bottom of the mast tops? I see no center axle for the sheave to spin on.
