Thanks, Brian! This kit is really nice!This is a most impressive looking model. Well done so far.
I'll be sure to keep the progress logged here on SOS as I move along, Uwe. And yes, you can never have enough clampsVery interesting log.....do not stop showing us your progress
PS: once more certified: you can never have enough clamps !
Thanks, ADC!Looks like a very high quality model and great work.
, today I installed the last of the false bulwarks and I'm pretty happy with the way it turned out, although there are some areas that need to be addressed once she sits overnight to dry. And I'm going to need a little advice on the matter at hand.
Hi there,
wonderful progress. Don't worry too much about yor first layer of planking. As long as is glued down firmly thats all that matters.
You can sandpaper and use filler smooth out gaps and imperfections before you start the second planking.
Hi John,
Always thinking 10 steps ahead is part of model ship building. I never look at a manual supplied with the kit, only for determining to use the correct part in the correct place. And yes sometimes you will face an issue but there is always a solution on the road ahead to fix it. I think your approuch of planking first is the correct one which enables you afterwards to build in the fully detailed deck. As we have a saying in Dutch: there are many ways that lead to Rome. Just choose the one you think its best.
John
What is keeping you from first do the outside. It is mainly about fitting wales and planks and the tree nailing. All the rest of outside detailing can be done in upright position of the ship. Once the canons are installed it is not easy anymore to put the hull on its side. If the strength of the hul structure is an issue you can decide to put a temporary enforcement into the hull where normally the decks are fitted.
If we're talking about the same thing, we call it Wood Filler. And I will be using itYou can also use a thin layer of molding paste (don’t know what it’s called outside the US) over the first layer of planking to cover the cracks in the planking as well as to strengthen the hull. Once dry, you sand it down to produce a smooth even layer to place the second layer of planking on.
No wood filler us something else. Molding paste is a medium that artists use. It has a white cream texture and it dries like a plaster. It goes on much smoother than wood filler.
