Ok, many "Wow, Wow!'s on your excellent workConstruction of the magazine (gun powder and cartridges) and light room continued this week with the addition of some details...
The floor of this portion of the ship is a layered affair which means everything can't be seen at the same time. To that end I will be skipping the lead floor lining. But I will include some palleting supported by beams and a segmented carling (beam posts interrupt the carling):
A closer look (note the perimeter rabbet):
And now with the pallets (panels) in place. The addition of battens kept stuff off the floor:
Very fiddly work all around.
Next, I added a box around the mizzen mast (open on one side for viewing):
This brought me to the forward wall of the magazine and light room. First, some wall panels were glued up and shaped to fit the contours of the hull. The little hatch/doorway on the far left will lead to a bread room:
The tiny window frames will eventually allow candlelight (?) into the light room. I had to wear stronger glasses for this part:
Mica was used for the glass. Here is the light box under construction:
A support piece was added to the bottom of the light box (and never to be seen again once the wall panel is installed):
And now (temporarily) in place:
I'm not sure if the light box is my best work on a model to date - but it's in the running.... That thing is super tiny and delicate - almost impossible to work on.
Until next time...
