Hello Friends!
More than a month ago I set out to add the bulkheads and rooms that sit on the aft platform. But as I studied the work progression, I realized that in order to fabricate bulkheads and rooms I needed to first locate the centerline posts that sit under the lower deck beams. But in order to locate the centerline posts I needed to know where the beams would be positioned for the lower deck (at least what I'm calling the lower deck).
Anyway, that's why (seemingly out of nowhere) I fabricated lower deck beams.
With those roughed out I then started working backwards toward the aft platform bulkheads and rooms. And the first job was making the centerline posts:
View attachment 431387 View attachment 431386
I chose to add a bevel to the corners. Here you can see one in position:
At this point I realized that the beams (which I had pinned into position) were still moving all over the place. In order to add more stability, I decided that I needed to add the carlings. But in order to do that I needed to cut tabled mortices:
And now with the carlings in place:
Which meant I could FINALLY build a bulkhead.
I started at the back where there is a magazine room (gunpowder and cartridges). You can see this (partial) bulkhead under the most aft beam:
The bulkheads and walls of the magazine are a complicated affair that are oddly thick and then filled with mortar.
Everything is just sitting there loose so don't be concerned with fit and finish - that will come later.
Question: is it normal to spend an entire day making a single small bulkhead? Asking for a friend...
