Wrapping up our weekend here in the US...
I have dedicated my modeling time to the construction of the lower capstan and the upper capstan. These two 'devices' share a common central barrel with the lower capstan (confusingly) sitting on the upper deck, and the upper capstan sitting on the quarter deck. For the capstans I actually used quite a few of the kit parts but then added brass to simulate the iron reinforcing rings on the trundle heads along with adding various bolts (copper wire).
Here is the beginning of the trundle head of the lower capstan:
Next, I needed to fabricate the central barrel. The barrel is faceted with 10 faces for the lower capstan (has 5 whelps) and 12 faces for the upper capstan (has 6 whelps). I was going to ignore the facets because they wouldn't really be visible when everything is put in place, but I am trying to improve my skills with some of the machines I have added to my shop, so I set out to make a practice barrel out of birch rod left over from my Vasa model. In the end I forgot this was a practice barrel and used it
I added the dividing head attachment to my little mill and used it to profile the barrel to the proper diameter for each section of the barrel, and then milled the facets:
Here is the lower capstan built and detailed:
And now the upper capstan:
I added a little disc on top for visual interest:
And now with some poly finish:
Finally, I added the pawls. I shaped these from brass bar stock...
Here are the capstans (loose fitted) on the ship (I ended up needing to cut the central barrel...the upper capstan sat about 1 mm too high and had to be lowered a bit):
I think it would be best to make some capstan bars though I can't say if they will be installed on the finished model or just shown stored.
As always, I am grateful for your kind attention to my modeling work...
