The Doc cuts wood and brass so finely that I’m thinking he’s a surgeon. Specialising in very small bones.
And thank you, Paul, for taking the time to take pictures of your exquisite work and share with the group!Thank you, my dear friends, for the likes and for the generous posts (Kurt, Smithy, Wojtas, Glenn, Ron, John, Brad. Johan, Michael, Frank, and Daniel). You are all very kind to take the time to visit and comment.
It took me a while to understand how those bloody things were supposed to work. Once I figured it out, I disregarded them as being machined on your secret, not so secret CNC equipment...No one even saw them but you, Brad! Oh how I agonized over those little bits .
This brings the rough fabrication of the square frames to a close. That's 55 single frames that will be paired at frame stations running along the length of the keel (with one triple dead flat set near the middle):
The right-hand stack should sit on the left stack but that turned into an unstable Jenga game...
Next, I will either continue my trials on bolts and trenails - or maybe just jump into the cant frames.
Yup, the technical lexicon can be picked up (and subsequently forgotten) rather easily with the appropriate resources.Much of the technical chat is going over my head at the moment but I have books to help out and so the thread is part of a pre-PoF training course for me. It's all very encouraging.
I sometimes wonder if I am more of a taker than a giver.
After not having been active at shipmodelling for 35-40 years and a recent, rather simple reastauration of an old schoonermodel, I jumped into the build of YQ's POF Bluenose.I want to try PoF, I have two kits on hand, but I doubt that I can build them so I’ve been planning a series of PoBs of increasing difficulty to gain experience.
So my advice would be to stop procrastinating and to start building your POF model...
Not a chance…Paul your contribution to myself (and many others - I am sure) has been invaluable.sometimes wonder if I am more of a taker than a giver.
Ha ha Johan I think you are indirectly talking to me…..3 years in and I still procrastinate about a POF. If Paul could send me a margin of his skills maybe I wouldn’t procrastinate so much .So my advice would be to stop procrastinating and to start building your POF model...
Please Grant, here I thought you being better than this, hiding behind someone else's capabilities...Ha ha Johan I think you are indirectly talking to me…..3 years in and I still procrastinate about a POF. If Paul could send me a margin of his skills maybe I wouldn’t procrastinate so much .
Cheers Grant
Please add my name to Michael's!We all make gun carriages in our builds, but when I see the quality of yours, it highlights the gulf in standard and capability of your building skills compared to the rest of us.
These are simply superb. It’s a pity you only build 4 of them.
Can you explain the process of applying the royal monogram to the barrel or was it part of the CNC machining?
Also how do you get the wheel pins (not sure of the correct nomenclature) into such small bits of wood with a tight fit and no splitting or damage to the wheel? Please don’t say boxwood?
Applause again Paul. I really enjoy seeing your work. It is an uplifting experience every time.
Your grandson is enjoying the effects of Fall. Uplifting too.
Michael
all...
I couldn't agree more. This really looks like a masterworkI had to double check these are 1:48 cannons!! The detail and accuracy you attain at this scale simply amazes me, as your work always does!
Like Michael, I am curious on your technique for adding the Royal Monogram...now that you've shared the results, you have to satiate our curiosity with another post, explaining your technique.
Thanks for sharing this work, and also the beauty of autumn leaves/children. Very special too!
Those gun carriages!! WOW Paul, as good as I have ever seen.
