Thats a very pleasant looking outdoor area for working on the model, Paul.
Good morning Paul. Breaking frames….must drive you mad. That little crack sound Eish. I also think with the amount of sanding required with boxwood increases the risk of breakage over softer woods. Beautiful environment to sit, sand, relax and suck in the feeling of the success……until the little cracking sound . Cheers GrantAnd now after preliminary shaping with a rotary tool...
The Kattner Sanding Center:
I have become increasingly frustrated by my (lack of) success gluing frames. You may recall that I dropped a bunch of frames earlier in the build and many of them broke (in some cases at the glue joint).
Since then, I am constantly repairing cant frames that are breaking off of the deadwood and at the top of the frames where they are joined with little filler pieces. I used Titebond and it is either old glue (Amazon) or the wrong product. It dries very brittle and I am now using PVA to make repairs. I would call it a learning experience but I'm not sure what I'm learning...
This a holiday weekend in the US when we remember those who have served in the military: freedom isn't free. Thank you to those who served so I can sit in my backyard and not have to worry about anything more concerning than glue...
Hi Stephan,I'm not a glue expert, but why titebond? We use here White glue. Pva you call that overthere I believe. You got 2 kinds D2 and D3, D3 is water resistance. Perfect for modeling.
Another thing is, you bought the kit second hand, how old is it, where was it stored? It could dried to much or something like that. Castello or boxwood is normally very strong.
I got this once with a piece of aliexpress, just 1 piece the rest was perfect. And the piece that broke wasn't like the rest. It looks, feels less dence and lighter.
Thanks Stephan. Titebond was recommended to me for gluing in places with an open end-grain as it was thinner and could soak into that end-grain better. I have found that to be generally true - the bonding surface that fails is the 'other side' of the glued joint.I'm not a glue expert, but why titebond? We use here White glue. Pva you call that overthere I believe. You got 2 kinds D2 and D3, D3 is water resistance. Perfect for modeling.
Thanks Maarten. You are correct. The wing transom does not seat fully into the sternpost (I actually mentioned this in passing in a much earlier post). As the rabbet has yet to be refined in that area (it remains undersized) I was hoping to 'solve' that problem later in the build but it most likely won't turn out quite right... Sigh.Paul,
I noticed that the top transom timber is not joining the rabbet in the stern post.
Did you check this with the drawings?
At the transome timbers the rabbet is wider.
Well, I guess the short answer is "I was just following the instructions" though in retrospect I can affirm that you are absolutely right. With the frames only connected at their ends they are quite fragile. I'm not using a vibrating sander but the sanding wheel in the rotary tool does 'chatter' a bit because of the density of the boxwood so things are absolutely vibrating.Good morning Paul, the rear looks really beautiful. If I may ask, why did you take it out of the mold and start sanding it already? From my experience it is very dangerous to do this because you have no stability in your hull, by sanding with a vibratory sander this vibration is transferred to the wood and the frames break again. I would leave the hull in the jig for as long as possible until it's fully built and then start sanding inside. Then attach the first reinforcements in the interior before I start sanding the outside, also attach a wooden strip to the top edge on the outside, this provides additional protection.
You can allways decide to flatten it and add a thin layer of boxwood on top.Thanks Maarten. You are correct. The wing transom does not seat fully into the sternpost (I actually mentioned this in passing in a much earlier post). As the rabbet has yet to be refined in that area (it remains undersized) I was hoping to 'solve' that problem later in the build but it most likely won't turn out quite right... Sigh.
I know none of you have slept well in anticipation of the preliminary sanding of the aft cant frames... So here is a photo tour:
The overall appearance:
Onward!
In truth I did sand off the tip of a finger - there are no fingerprints left so I can now pull off that big heist I've been contemplating...You mean you’ve been sanding so much the midships section is no longer there
