Thank you, Heinrich. An additional step here is the setting of the sail/yard loosely and pulling the "bundles" of brail lines and sheets fore and aft to clear them out of the way to secure the two fore shrouds.
That disclosed that both were too long not having accounted for the rocker upwards. Had to resort to my acetate and patiently remove the spliced shrouds from around the thimbles and redo those to a matching separation to the partner aft.
Here are three views after I shortened the stbd. shroud and working under the sail pulled forward put it in place.
Moving forward to look back on the same side:
And from more aft looking fwd:
This was a good step as it lets me consider where to lead the various lines and set some belaying pins for a final set. I am thinking that the two aft quarter rudders will be the last items to attach as they will be too exposed to damage.
I am not sure if I want to go the extra setup to have the sail/yard in a windward tack as all lines would need to be changed to the correct pins for photos. I know that the give-away presentation will be with a squarely set "downwind" sail and lines. There would be a lot of time spent in setting and resetting the lines. Rich
