Uwek, what are the difference(s) in the Proxxon Pen sanders?
Thanks!
Thanks!
Thanks!
Hallo Ron,Absolutely stunning kit and workmanship! Your workshop leaves me a little envious as well! I was wondering about the use of various grades of steel wool
for final smoothing other than sand papers. I use steel wool for fine furniture refinishing as the wool tends to shave/slice off wood instead of disturbing the fibers with paper.
I have to try this. Sounds like a great idea.I was contemplating the use of actual steel wool for it's slicing/scraping qualities versus something that would lift the wood fibers. It comes in a multitude of grades from 00 super fine all the way up. You can almost get a luster from some hard woods if used correctly. Sanding in the normal way is perfect for taking surfaces down quickly.
I use this in the finer grades when I turn wood on the lathe, it does give a beautiful lustre to the wood, you got to be careful on the lathe though that you only have a small wad of it, otherwise it can wrap around the especially small turnings,
best regards John.
Hi Uwe
Nice work you are doing.
The pads look like the same things we get in NZ for cleaning glass cooking dishes.
You can get them from any supermarket.
Denis.
Thanks for the hint.....I saw them already, but I do not have them until now. I am pretty sure they are working well to press the needle into plywood, but in solid cherry i have my doubts. Maybe with drilling a hole before with smaller diameter than the needle. I will order them and give them a chance.Hi Greg,
Do you know these clamps, seems to be great for solving you clamping issue.
https://www.schiffsmodelle-shop.de/en/special-tools/22246-planking-clamp-set.html
