Yes you are correct. I have to stiffen the frames with some small timbers between each frame and afterwards I have to sand the complete hull inside and outside. Because of this working step I left some „meat“ and did not made the final sanding earlier.....so still the frames are only rough preparedHello Uwe ,a big step accomplished,the framing looks very nice,although I still see some laser chars.
In moment I have carefully sanded the tops, so that I could glue the small strips on both sides, but only temporary.How will you sand all those “ribs”.
Hi Uwe,
With this type of build is there also a lot of “fairing” (is that the right word?) required before planking?
