- Jan 21, 2022
Thank you.
Great technical help.
I use the drawings and does it look right.
With eye on spec.
Technically correct is great unless it is looking wrong to eye or misleading.
As we know scales cannot be relied on : 1:500 scale piston will not be the same as 1:1… especially in output …. yes?
I take the old masters view - they built the shipwright models to show an interpretation / design idea. Then discuss.
Reality
Can be different ….
Of course they knew different hull lines brought differences.
Some of the Administrators had there choices, too.
We not have the original ships - just a would be drawing which changed as work progressed. Even the paint differed - paint it blood red or wait until we get ? From ? No worry about needing the ship.
TTFA and happy building![]()
The last couple of days have been working on planking the decks, I am trying to plank if possible as much as I can before installing the deck's exterior panels in the bow and stern areas it is much easier!Thank you.
With eye on spec.
Reality
Can be different ….
The forward Deck has me thinking as there are 4 to 6 cannons positions under it and that deck looks to me like it must be installed before the upper exterior planking can be done? so the placement will need to be done later looks tricky to me!!???
