L'Amarante Corvette de 12 canons 1744 1:36 POF (Ancre Monograph- Gérard Delacroix) By Shota
I am a little behind on your build but it’s always a pleasure to follow your excellent, informative work. The floral decoration with the laser burner is most impressive. I think I need to learn more about laser burners :).
Dear Roger
thanks for your kind words and compliments
I will help you with a great pleasure
I think you should take a look on Bill Short on MSW, he also sells here a PDF on how he does the carving. It's simpel and with a little practice you can make wonderful things and in combination with your laser tool! It can be even more.
thanks for your kind words and tips
can you give me a link to Bill Short work on MSW,
Reading this and looking to tips from Janos in the carving section is for free. And rotary tools look for these:
Good evening dear friends
Tonight I applied the process of experimenting and learning from yesterday on a boxwood board.
I made two opposite cuts of the motif with a thickness of 1.6 mm and connected them so that both sides came out the same.
I will let you get an impression of the intermediate result.
in the coming days I will practice hand carving the flower decorations and the lines of the wreaths.
Good night and hope you like the results, any instructive/advisory comments will be gladly accepted
20240917_211513.jpg20240917_211743.jpg20240917_211813.jpg20240917_224443.jpg20240917_224503.jpg20240917_224527.jpg20240917_224640.jpg20240917_224659.jpg
View attachment 471637View attachment 471638View attachment 471639View attachment 471640View attachment 471641View attachment 471642
Brilliant!
Witaj
Podoba mi się Shoto trochę bym dopieścił pilniczkami ale że ty potrafisz rzeźbić to spróbuj. Pozdrawiam Mirek
Brilliant!
Beautiful work. And inspires me to do more with my laser cutter.
About soot: I read somewhere that wetting the wood helps. But be sure to do some tests, as I can see a risk at warping.
Thank you very much, dear friends, for the praise and words of encouragement
Indeed a damp wipe helps in cleaning the soot
In the last few days I started working on the hatches of the 12 Cannons windows add the drainage.
it's the first step in the process of creating the openings requires more gentle and smooth sanding of the openings as well as the creation of the slightly concave window base. For that, I purchased a matching milling had
20240921_104033.jpg20240921_111303.jpg20240923_211549.jpg20240923_211629.jpg20240923_211826.jpg20240923_211506.jpg20240923_211900.jpgScreenshot_20240923_215238_Chrome.jpg
Good night and peace everyone
View attachment 472588View attachment 472590View attachment 472593View attachment 472594View attachment 472595View attachment 472598View attachment 472596View attachment 472597
I'm curious what the result of that 'heavy half sphere' will be, Shota. But just like your ‘laser carvings’, you'll have thought about this.
In the last few days I continued with the experiments and working on the windows of the cannon openings.
First I performed two processes at the same time to find the best process for me for the windowsill. The first I sharpened and created a curved razor and the second I examined the results of the special nibbling. After two attempts I chose the window sill that was made with the chisel.
In the picture of the parts on the saw, the only window sill on the right is the one that was made by hand.
Later I decided to build the window frames from boxwood while the planking around them will be from pear wood. I also decided to give a personal interpretation and add two thin side panels with a thickness of 0.45 mm to the window frame.
For now I have installed 6 window sills and I made one window in its entirety, I admit that this strengthened my choice of design henna and the combination of the different shades of the trees.
Attaches documents documenting the steps in the work process and the intermediate result.
I wish you all a fun and safe weekend
20240925_213604.jpg20240925_214807.jpg20240925_214817.jpg20240925_215144.jpg20240926_210759.jpg20240926_203136.jpg20240926_210813.jpg20240926_211322.jpg20240926_211405.jpg20240928_161840.jpg20240928_161850.jpg20240928_173800.jpg20240928_173811.jpg20240928_173806.jpg20240928_173833.jpg
Very nice result, I can still remember the process at La Palme. I filed a piece of wood to size and covered it with sandpaper. I also had three different window sills to choose from, but I decided to go with the pear-shaped version.
from left to right: pear, boxwood, ebony.
as you know, I'm always checking your magnificent models
it's helping me a lot
