I am a little behind on your build but it’s always a pleasure to follow your excellent, informative work. The floral decoration with the laser burner is most impressive. I think I need to learn more about laser burners
**VIEW THREAD HERE** |
Dear RogerI am a little behind on your build but it’s always a pleasure to follow your excellent, informative work. The floral decoration with the laser burner is most impressive. I think I need to learn more about laser burners.
thanks for your kind words and tipsI think you should take a look on Bill Short on MSW, he also sells here a PDF on how he does the carving. It's simpel and with a little practice you can make wonderful things and in combination with your laser tool! It can be even more.
Brilliant!Good evening dear friends
Tonight I applied the process of experimenting and learning from yesterday on a boxwood board.
I made two opposite cuts of the motif with a thickness of 1.6 mm and connected them so that both sides came out the same.
I will let you get an impression of the intermediate result.
in the coming days I will practice hand carving the flower decorations and the lines of the wreaths.
Good night and hope you like the results, any instructive/advisory comments will be gladly accepted
View attachment 471637View attachment 471638View attachment 471639View attachment 471640View attachment 471641View attachment 471642
Witaj
Podoba mi się Shoto trochę bym dopieścił pilniczkami ale że ty potrafisz rzeźbić to spróbuj. Pozdrawiam Mirek
Brilliant!
Thank you very much, dear friends, for the praise and words of encouragementBeautiful work. And inspires me to do more with my laser cutter.
About soot: I read somewhere that wetting the wood helps. But be sure to do some tests, as I can see a risk at warping.
True storyBrilliant!
I'm curious what the result of that 'heavy half sphere' will be, Shota. But just like your ‘laser carvings’, you'll have thought about this.Good evening dear friends
In the last few days I started working on the hatches of the 12 Cannons windows add the drainage.
it's the first step in the process of creating the openings requires more gentle and smooth sanding of the openings as well as the creation of the slightly concave window base. For that, I purchased a matching milling had
View attachment 472588View attachment 472590View attachment 472593View attachment 472594View attachment 472595View attachment 472598View attachment 472596View attachment 472597
Good night and peace everyone
True story
thank you very much my dear friends for your kind words, I'm doing my bestI'm curious what the result of that 'heavy half sphere' will be, Shota. But just like your ‘laser carvings’, you'll have thought about this.
it's a very kind words, thanks RogerThose ports are looking good Shota, I like the way you approached it. As Peter @Peter Voogt mentioned, you have thought about this and always come up with a good solution.
Stay safe.
as you know, I'm always checking your magnificent modelsVery nice result, I can still remember the process at La Palme. I filed a piece of wood to size and covered it with sandpaper. I also had three different window sills to choose from, but I decided to go with the pear-shaped version.
from left to right: pear, boxwood, ebony.
