Very good build Uwe, your build log is exceptional and will be of great help to those building or thinking of building this wonderful kit
Slick work as usual Uwe. I see you installed frame 3 and 2. What did you use as reference, the 3 D drawings from Manual 1 or the larger 6-3 drawing which does not clearly indicate where frames 2 and 3 need to be fixed to the deadwoodSo I started with the inner planking works first with the first four rows.
And you see, that I left between the keel and the first plank a gap for the limber board
You maybe recognize the dark stain on the planks - this was my fault, due to the fact, that I was butting a steel weight on top of the planks during watering - hope that I can remove it later on with sanding....
Where to start with the first plank I tried to follow this drawing from CAF
Here are the planks shown also with the limber board gap
and now the planking finished with sheet "1 O"
Two hints, which are helping maybe also other modelers:
1) Put the strips for some time in water before you try to adjust and install them - this is making them much more flexibel and you can adjust them
2) It is every time not easy to fix inner planks correctly during the glue is drying - so I used wood glue on every 50% of the frames and 50% superglue, especially at the ends of the planking -> for me this way was working very good
I think it is the second you mentioned -> the drawing for the outer planking where you can recognize the location of the teeth in every frameSlick work as usual Uwe. I see you installed frame 3 and 2. What did you use as reference, the 3 D drawings from Manual 1 or the larger 6-3 drawing which does not clearly indicate where frames 2 and 3 need to be fixed to the deadwood
Yes, I did not make the thick stuff like shown in the Boudriot cross section. The problem is also, that the thick stuff planks is following the area where the parts of each frame are connected.As always, clearly arranged and very well done. I am curios how the limber board will look like. There is probably no thicker plank after the 5th plank from the keel, as shown in the Boudriot Plan?
I am happy, when I can be of some help for future modelers of this kit - also in a way, to see and help to make decisions sometimes in another direction, to solve or make things in a different way.Terrific, I was wondering what type glue you were using. I will be starting my Coureur in Dec. , and I'm sure I
will be referencing your posts frequently . Thank you for all the info.
Hallo Poul,I'm not 100% sure but at the @CAFmodel build it also looks to me as if there are a couple of stealers. Only a bit lower than yours:
Yes and No - It is slightly differentDid the top plank of your section 1O fit with the bottom of the measuring sticks ?
I was thinking about this way, but I thought, that if I have to adjust the lowest one more, than it will be later on much more visible.Do you think maybe for section 1Q it would be an idea to start from the top just below 2A-3 and then working downwards towards section 1O?
Counting the planks I think you are right PoulLike Chello I don't get it. The shapes of the 1Q boards are very complex - to say the least. Why having all the trouble designing such complex shapes if they does not fit anyway? It simply doesn't make sense to me.
BTW: I did not mean the measurement sticks above the deck clamps. Maybe I'm wrong but to me it looks like there are also some measurement sticks for the topmost of the 12 planks in section 1O:
For me also notLike Chello I don't get it. The shapes of the 1Q boards are very complex - to say the least. Why having all the trouble designing such complex shapes if they does not fit anyway? It simply doesn't make sense to me.
