LE COUREUR - french Lugger 1776 - POF kit from CAF in 1:48 by Uwe
BTW one additional information related to the used copper nailing of the outside hull planking.
In the meantime the nails got back there slightly red copper color - so the shining and glossy appearance is disappearing with the time.
The outer planking was not treated with oil or something else until now - so pure natural timber and copper
Perhaps you can help me Uwek. I cannot, anywhere in the plans find reference to these steps. Nor can I find any semblance to them on the wood sheets. Can you direct me ?.... were the heck are they !
Hallo my friends,
sorry for the late reply, but it was a long weekend here in Austria (Thursday to Sunday) so this time is reserved for the family (and workshop) with a partly abstinence to I-phone and laptop.....
The ladders which I am using are not included in the kit. It was a special laser cut sheet, I received once from Tom for testing, which are fitting well to the Coureur.
I told him already, that he should and could add them to the Le Coureur kit......
Here two photos which I made building them - I used double sided adhesive tape to fix the two ladderbeams, so it was easy to install the rungs
final result
some more progress on the carlings and beams
IMPORTANT:
Be aware, that you do not fix the carlings left of the ladder (on the photos still missing) before the fireplace / oven is finally installed !
So FIRST oven and onyl afterwards the last carlings .....
and moving to the sail room at the bow with the mast partner
As mentioned, it will be necessary to finalize and install the oven before you can close all the beams and especilly the carlings over the top of the oven
As usual first the manual sketches to get a detailed overview of this working step - a small project inside the project
Included in the kit are four nice and very realistic wall elements made out of real clay - each brick is visible - so I am very happy with this solution
Nevertheless the work with these has to be done very gentle and careful, they can break easily
First step was the base element, drilling six holes for fixing the three brass elements (also included as a wire in kit, which has to be bended into the correct form)
Here you can see the the backside wall - the three brass elements are made out of scratch with the use of some 0,2mm brass sheet and the rings are made out of a 0,4mm brass wire
Maybe you recognized already some change in the color of the bricks - I painted the slightly orange clay with Ecoline watercolor pen to get a darker red
and here the final result of the oven with the base and the three side walls already inside the wooden box - I used for the ringbolts (with which the oven will be fixed inside the ship) the kit content - they are slightly too big, but I was too lazy to make eight from scratch - to be realsitic - it will be hardly visible later one
I discussed this with Tom some days ago, and he will add in future some bolts to the kit, which are more scale correct
with an scriber I made also some small holes into the wood, in order to imitate some nails (but this is only for me -> nobody can see this detail later on
Only to comare the size of these two heating places which have to be installed in the Le COUREUR
and now the oven at his final place
Many Thanks for your interest .... to be continued .....
In order to finialy fix the oven the oven has to be tied up by the eight ring bolts with the inner planking.
It was not easy to handle, but somehow I was able.
Keep this in mind, when you come to this working step...... install the oven first, before you glue any beam or carlings at this area
This is the final result
Now, after fixing the blackened brass roof the oven is finalized
Some fire-wood next to the Oven - fixed between the ropes
the overview of the interior at this stage of construction - Note: the barrels etc. are only dry fitted in order to find out the final arrangement
Amazing detail and workmanship. I'll be at this stage many months from now, but looking at your build has been a guide and an inspiration. Bravo !
Hallo my friends and modeling collegues
first of all many many thanks for your kind words about my progress - and also the likes received
Today I can show the final arrangement of the cargo in the cargo compartment
I am not a specialist of correct lashing cargo in such a small hold...... I am pretty sure, that there should me more ropes, maybe crossed over the barrels etc......
I tried to simulate somehow some lashing........ Maybe my model is simulating the status still in harbor during the loading and lashing the cargo - both works are shown in between and not finalized, because there are still to barrels of red wine missing, which will be delivered from Bordeaux ;)
But now the photos
I added also some firewood - sometimes it is cold and the captain likes to have it warm in his cabin
but most of the wood will be used by the ships-cook
In the center you can see the Chopping block for the firewood - I am still searching for a miniature axe in correct scale
And to complete the sequence some views through the space between the frames
Many Thanks for your interest - to be continued .....
