LE COUREUR - french Lugger 1776 - POF kit from CAF in 1:48 by Uwe
Changing the waterways, like I did, will produce some necessary adjustments of the planking, which will try to explain in the following
all planks are laying on the deck (without waterways (here you can see once more the mixing of the planks because of the wood grain and annual rings)
This photo is showing the deck planking with the original kit waterway
you can see, that because of the bigger width of the waterway-plank the center of the planking is moved out of the center -> when you use the kit waterline you have to adjust this with reducing the width of the waterway plank
here the planking is centered and you can see the approximate area, which has to be reduced - mainly at the area towards the bow, midships it is fitting very well
Now my alterantive waterway -shown are the dryfitted waterways close to the framing
and here you can see the planking centered and also the alternative waterway at its place -> and you can see some gaps between the planking and the waterway
For comparison reason you can see the original kit waterway at the center of the photo
appr. at this location the gap between the frames and the planking has the same width of my alternative waterway. From midship to this location I have to widen the planking to fill the gap, and from here towards the bow the planking can be sanded and adjusted to fit in. As I mentioned already my waterway has a continuous width of 4mm
and here the alternative waterway with all planks (dryfitted) layed on the deckbeams
This I am showing, that everybody who wants to change or adjust the waterway, should be aware, that you have also to adjust the last outer planks
So still some works to do
Because of this, I mentioned in one earlier post, that the planking job will need some time to build ......
to be continued ......
Today a short update on the planking works
First I tried first time the use of the ECOLINE paints to immitate the caulking
Here some trials with the same wood used for the hatches - on the right side without Ecoline, on the left painted with black Ecoline
and here the result on the deck planking wood
I was happy with the final result, so I decided to use the "Ecoline-technique" on the complete deck planking of my Coureur
I painted both contact sides of the planks
This photo is showing the first group of planks -> Due to the fact, that Ecoline is waterbased the wood glue is getting also black.
YES - It is looking terrible, but wait until you see the final result
Here the same planks after scratching
and the planks on the deck - here the center part is finished, the planks parallel to the waterways are only fixed with adhesive band
I am happy with the result, the caulking line is looking in my opinion realistic - definitely it is faster and easier than to handle thin paper between the planks
Many Thanks once more for the kind wrds, comments and like received - much appreciated and a real motivation.
I know, that sometimes it is a little bit boring, but as mentioned earlier already, this log should also help the modeler of the same kit to see how to do or not to do some details.......
Before gooing further with the deck planking works, I decided to make also the hatch and hatch covers (this ship had no gratings at all)
as usual you can see the sketches of the manual, so you can understand to work in a better way
First of all the main hatch over the cargo room
and here you can see the detail in the Boudriot nonograph
BTW: visible is the detail, that the hatch frame is sitting on top of the planking and not on the beam
The elemnts are in such a way prepared, that it will be possible, that all hatch covers can be opened and closed
-> one additional way to have an additional insight into the hull to see the interior works of the finished model :cool:
I made a first trial how to immitate the caulking between the boards of the cover - here I used also the pens of Ecoline - BTW: very easy to apply
on the right you see without - on the left with "caulking"
the first cover is started with the boards
The bottom view with the started framing
The top view
With the help of the cover also the hatch frame was produced - somehow I used the cover as a jig for the correct dimensions
The hatch at the correct place (still fitted dry)
and the hatch with closed cover
And now the other remaining hatches and hatch covers have to be prepared
(remark: please be aware, that the parts 1Y-3 are numbered wrong: correctly it should be written 1Z-3)
This is hatch No. 68
and the same opened - later on a ladder is installed under this hatch, so that the ships-cook can easily bring the captain a cup of coffee
hatch No. 69
and also shown open - here I installed a monkey ladder
and finally hatch No. 70 which will be installed directly infront of the rudder - it is the smallest hatch cover
Finally you can find photos of the four hatches with hatch covers for an overview and comparison of sizes and the way of construction - all four hatches are different in the way they are constructed, therefore I show them all visible from different persepctives
Hatches and hatch covers separate:
and closed
Remark: hatch No. 70 is here on the wrong place and should be more aft - on this (wrong) location a skylight has to be installed
The hatches on top of the Boudriot drawing
and on top of the CAF drawing
Remark: you can see that the drawing is showing hatch No. 70 bigger than the model-hatch - this small error in the drawing will be revised in future releases of the kit -> the kit is correct, only the drawing is wrong
In order to see the contrast between the planking timber and the hatch timber
Still missing are the eyebolts and triangle rings for lifting the cover - will be done later -> now it is important to have the hatches for the correct dimension of the openings in the deck planking
hatch No. 69
and closed
A wonderful primer on hatch cover construction Uwe.
Before further working on the deck planking it is still necessary to install the last beam and the carlings close to the stern of the vessel.
But before I can do this I decided to drill and open the hole for the rudder
First drilling a smaller diameter, afterwards with a bigger diameter and the rest was done with different types of my rasps and files
view from inside the hull
and from outside - later on, when the rudder is finally installed the rudder hole will be covered and closed against "splash water" with a fine leather (which is included in the kit fittings - btw: very good material
Here you can see the test with the main rudder parts, which have to pass the hole
I am in moment not 100% sure about the size of the hole, if it is big enough to let the rudder turn - but the total size can be easly adjusted and widened also afterwards. Now it was time to install also permanently the last beam and carlings (no photos made)
After the last bea, is installed, the planking works on the upper deck can be started
First work was the installation of my "alternative" waterway (lengthy description of my thoughts about waterway you can find several posts earlier)
You can recognize already three planks installed with the waterway
I will not install all planks, but will leave some area, so that you can see a little bit the interior under the deck
Here waterways and the planks close to them (2 and 3 shorter planks) are fixed, the middle part and the single planks are only dry fitted
Before fixing these planks several works have to be done before - but you get an impression, how it will look like
With this (not very good made) photo I checked the visibility through the frames - enough light through the space between the planks so something is visible
Mayn Thanks for your interest .... to be continued
Before cutting the openings into the deck planking and also before sterting the treenailing of the deck I decided to prepare also the deck-superstructures.
There are two lighthouses and also the staircase descent (hope this term is correct)
As usual the three capters with sketches in the manual in oder to understand the works better
First small project inside the project was the staircase structure with skylight
Let us start - these here are the parts for the structure 84
After some very light sanding the brass window frame was fitting exactly inside the opening of the wall elements
The two wall elements with the window frame (after blackening) from inside
and the same with view from outside
I was afraid, that the transparent folio (included in kit) could get "foggy" with using superglue, so I decided to use double sided adhesive tape -it worked very well and is not visible later on
The elemnt installation on top of an double sided adhesive tape - this tape is helping very much to keep the elements in place until the wood glue is dry
the wall at the left has to be removed later on, after the roof boards are fixed
First deck structure is prepared
Here you can see, that also the temporary wall is removed
view from the backside
and both sitting ion the correct place
at the end, I want to show the doors open to be able to look down the staircase
absolutely amazing Thumbsup Thumbsup :)
Many Thanks for your kind comments and the likes received - much appreciated
Missing is the third small skylight which will be installed on top of the captains room
glued but not cleaned and without final sanding
after final sanding on top of the final palce
on top of the deck planking - now it is time to start the cut of the different deck openings
pre shaped openings
but before the final shaping of the openings I have to fix the planking on top of the beams, and before this, I decided to make also as much as possible of the treenailing of the deck planking -> step by step
to be continued with the treenailing works - coming soon
Уве, добрый день. У меня вопрос. Крышка люка на этом фото наклеена? Если это так, возможно, стоит снять фаску в этих местах для более плотного прилегания облицовочных панелей.
Uwe good afternoon. I have a question. Is the manhole cover glued in this photo? If this is the case, it may be worth chamfering these areas to make the cladding fit snugly.
Many Thanks for your comment, and it is good, that you asked this - A very good point and important
What you see is an optical illusion, better a different interpretation of what you see
I guess with chamfering you mean, that I should sand the boards of the roofs in this way, or?
I did
What you see are the small displacements of some mycro millimeters - as mentioned the photo was made before the final sanding an adjustments (but with fixed and glued roof boards
On this building you can see them also slightly, but after sanding the ends of the roofs you can see not anymore the gap
With this overview you can see, that I made the chamfering of the boards
A very good point and for the final appearance very important !
Hi Uwe, I am not a member of this build group so I have been reluctant to post. But I have to say that your work is exemplary at every level. I love to watch from the sidelines learning what can be accomplished by an experienced builder who loves the hobby enough to share all his secrets with other builders. Your attention to detail and hand-skills to build those details puts you in the top tier in my opinion. Bravo!
Hi Paul, that's exactly it and not everyone can convey it the way Uwe does.
pre shaped openings
Dear Uwe
The construction / creation process you presented and the result are very beautiful and instructive, well done and thanks for sharing
Once more many thanks for your kind comments, hints and likes - it is realy motivating to procede in this manner (the modeling and also the log)
The next step I jumped in was the treenailing of the deck planking.
Often we have the discussion, if a model should have deck-treenailing - some modeler have the opinion, that treenails in the model should not be made, due to the fact, that on real ships, the nails were made out of the same timber like the planks, so the nails would not be visible, especially in a model scale. This is correct.
On the other hand, as a modeler is his own "artist" in creating the appearance of his model, at the final end, it is a pure question of taste.
I usually make treenails, often as fake nails with some wood putty or similar with a slightly different color like the planks.
Here on the Le Coureur model I tried it first time to use simple toothpicks, which have originally a similar color like the kit planking wood.
So making first a sample planking and used also some different Ecoline paints for the peak
The three rows on the left with black, the two rows in center without additional color and the two on the right with some ochre
(now the sample is turned by 180°)
and these are the final results of the treenail samples after scraping and sanding
with black paint - very good result, but very dominant
looks dirty - maybe also the exacution was not done with accuracy - because from the beginning I had already my favourite
my favourite solution - toothpicks without any treatment, only a very small volume of wood glue on the peak before I hit the pick into the predrilled hole (0,5mm)
