An interesting action that happened when I was firing my small blackpowder cannon, viewed in very slow motion, was that the carrige would "leap" up and backwads when the shot was fired. The breach was not elevated very highly to drive the carriage downwards. Leaping guns with tons of weight would definately be a hazzard if a full sized gun would recoil in the same manner. Nice work on your part. Rich (PT-2)My friends,
many thanks for all your comments, hints and remarks - and off course also for the received likes
Before I started with the guns, I made the preparations on the hull, means the installation of the bolts for the gun tackles visible outside of the hull.
Here the manual descriptions for your information
shown are two bolt ends located at each side of the gunports - the upper one for the ringbolt for the tackle and the lower ones for the hooks of the breeching rope
The inner ringbolt and hook I decided to install later on together finally with the guns - it is much easier to prepare the complete tackle incl. the ringsbolts and hooks at the gun, compared to the necessary work to fix the tackle, when they are already installed at the railing.
As usual I compared the bolt solution with the Boudriot monograph
and photos showing scratch build models
and realized, that there are outside only two bolts at each gunport visible
closer look at the Boudriots drawing of the Le Coureur is showing us a different type of fixing the gun tackles and breeching rope - unfortunately no sideview
Only with this drawing I did not understand, how this bolt could look like (nowhere else in the monograph is shown something), but I found the final missing info in the monograph of the Le Cerf also by jean Boudriot.
so it is a combined hook with implemented ring
Once more it is getting clear, that the recoil forces of such 2 and 3pdr guns was not very high.
From technical point of view I have my doupts (this is now brainstorming), if such a combined ring-hook was really working well ?!?!
Usually on bigger or other guns the fixing points were organized like this:
The hook or bolt for the breeching rope is lower installed than the ringbolt for the gun tackle! So the tackle of the gun was everytime free to remove from the hook or not covered by the breeching rope
I am sure it was partly problematic with such a ring hook
beacuse here the ring for the tackle (green) is installed under the hook of the breeching rope (red)
see also the photos of a Le Cerf model
View attachment 258743 View attachment 258742
I guess it was sometimes no easy to handle and the ropes were sometimes, after the gun recoiled, not easy to get free or to handle......
Sorry for the longer and maybe for a lot members uninteresting subject, but I am still thinking about to make one combined or two seperate fixing points........
Very nicely executed work here. May I ask what the scale of the ship is? Also the treenails as I will be using something probably smaller on my Kryenia boat to simulate the same for the mortise and tenon hull strakes which were not "nailed" to frames but created a shell for the gull itself.Many thanks to all of you for your comments, information hints and brainstorming - still open for comments off course.
It seems, that such combined hooks were used on french smaller ships (like the Cerf, Amaranthe etc.
Nevertheless I have also my doupts, if I am able to produce 16 of such hooks with an acceptable quality.
My first attempt using a hook and adjust it was failing, so in momenr I do not see a good solution. I guess also, that the best would be casting some.
But I have some more time to decide and produce, until I finally fix the guns on the deck
For now I made only one level of iron bolts on the outer side of the hull close to the gunports
I used the small rings of the photo etched sheet and a 0,8mm brass wire pieces
blackened these parts
and glued them together
and these "bolts" are now looking like these
and a better view from the side - I think they are looking realistic
That's the hook, man! How was it made, that's my question.Hello Uwe, L‘Amarante also has this ring / hook combination
That looks like some patient bending, hammering and filing to shape before drilling the hole for the ring. Must be in a small scale, large piece, size. Just thinking . . . ?????That's the hook, man! How was it made, that's my question.
Based on the hint with the Amarante made by Tobias - we do not have to look so far awayThat's the hook, man! How was it made, that's my question.
Hallo Rich,Very nicely executed work here. May I ask what the scale of the ship is? Also the treenails as I will be using something probably smaller on my Kryenia boat to simulate the same for the mortise and tenon hull strakes which were not "nailed" to frames but created a shell for the gull itself.
Rich (PT-2)
Thanks for the process and link. I'll look at that. My pending need will be very small in dimensions of the 1:43 scale as in the actual 1:2 the tennons were spaced 12 cm apart side by side and with anchoring pegs 6 cm above and below each strake fastening them together. The tennons were staggered between those above and the next one below in a Z type of layout for the lengths of every strake. Taking 12 cm full size down to 1/43 scale is a very small dimension and lots of those simulated treenail pegs which were then also set with a copper nail being driven into the end. What copper nailing that was done was driving fhrough members and clinched on the interior face with a long and shorter leg making a type of U shape to the inside nail shape which I will likely have to disregard and not execute. 1:43 is a larger boat than 1:48 but still a small size for me to work with. RichHallo Rich,
the scale is 1:48
The treenails you mentioned, and I guess you mean the hull planking and not deck are (better to say) boltings and not wooden treenails. The french used for such clinker built hulls mainly bolts to fix the planks - I was using here small copper nails with diameter 0,5 mm for the planking and 0,6 mm for the wales.
Just checked the posts in my log - I started with the preparation and the nailing this February, so if you are interested in more details please check the lengthy descriptions starting from here:
LE COUREUR - french Lugger 1776 - POF kit from CAF in 1:48 by Uwe
Like a Nudelwalker :Dshipsofscale.com
View attachment 259074 View attachment 259075
link and copy of photos in my post #1047 of this topic...... scroll shortly backwardsYour canons are on the right way, Uwe. Please, can you show me Giampy´s post if availible ?
The length of the barrel looks too long for the carriage but I recall that some calibers were cast with long barrels. It looks nice in place. RIchI have still some time until the inner hook question has to be decided, nevertheless I will try once the way shown by @Giampy65 with the additional "material" - some experiments have to follow
View attachment 259555 View attachment 259556
So definitely some time to start with the "main guns" of the Le Coureur.
the words by Jean Boudriot....
and here as usual the sketches in the manual
The different parts of the guns are well prepared and of very good material quality
I started first the assembly of one gun in order to test the different working steps. Afterwards, when everything is tested I am able to start the "mass-production" of the remaining seven guns
I first step was done - so I will now make the other seven wooden gun carriages - until now no "metal" works done
These guns were only 3pdr guns, so relatively light barrels or muzzles.The length of the barrel looks too long for the carriage but I recall that some calibers were cast with long barrels. It looks nice in place. RIch
