- Mar 19, 2020
I agree it is best not to glue anything other than the two support pieces.You are absolutely right - when I saw this sketch (and others) from the second manual
I realized this also
The base elements B1 and B2 can be used also as a solid base for the deck, rigging etc. works.
- we have to think which connections have to be fixed and which connections should be loose or only temporary fixed with only some spots of glue
It looks like that the slots in the base for the vertical parts A2 and A6 can be used
Once all parts are “clicked” properly in place the jig is very sturdy. I did screw the bottom pates to a solid plank for more stability as advised in the manual.
Great work as usual Uwe!!
