Uwe, watching your thoughtful an clean handwork is a real pleasure. Because of you one can bwtter understand the complicated structure of the stern.
Many Thanks for the comment - So hope to see an update on your log soonLooking good! About 20 frames behind you.
That is really clever. And it solves the issue of frame 35 determining the order of which the frames must be glued in.In other building log was a short talk about the fitting of frame 35 in the jig.
I had the same problem, and after checking the frame by itself, compared with the drawing, I was convinced, that I have to adjust slightly the jig, so that the frame can fit in. So I removed a little bit of the jig at frame 34 and 35 - this was my way .....
Yesterday I fixed the first group of frames on the keel
and during waiting the glue drying I filed the two mast foots into form
Correct - I removed this small part (which is not really necessary for the future work) and than it is possible to remove.....it was only a question of maybe one milimeter missing.Looks very good Uwe
I have been reluctant to glue the stern structure because I realized there is no way I'll be able to get the keel in and out of the building berth once this is done. The middle stern timber as well as the lower transom is locked in upward direction and the side-counter-timbers (or whatever they are called ) will be locked so it cannot be moved either sideways or forward. I have been really puzzled how the heck you took it out again. Now I have just notices some mods. you have done to the berth (red circle) and I wonder if these mods was made after you glued the side-counter-timbers and if this mod. is the reason you were able to take the keel out?
Hallo Maarten,Hi Uwe,
Good to see you were working from home yesterday, hope you are all OK, we sometimes live in a crazy world.
Your Coureur is coming along very nice, with this complicated frame contruction she looks to be a very intriguing build.
