- Jan 21, 2022
I'm curiose how you'll handle it, because soon I'm going to have the same problem. Fortunetly I don't have to make any beams as SZKUTNIK gives them as a part of 3d hull. So I'm left only with how to make decks. For now I try to not think about it as I still have some unfinised port lids and next in queue are gun carriages. So I'm counting on you to do them before me-decksHi WojtasS,
Thanks for sharing this. Andrey Kudin's application constructing a false deck is actually one that I am considering. My first choice is to create deck beams aligned with each bulkhead and then lay thin plywood + deck planking. The only other solution I would consider would be creating every deck beam in the plans and then deck planking without the plywood. I'm still working out which would be the best solution, for me considering, my skill set, effort and quality of the finished work.
I need to look deeper into Mr. Kudin's masterful work.
Thanks again for your help!
Certainly, there is more PoF knowledge available to me for reference. It's a moot point now as my Le Fleuron ship is no longer moored and has exited the harbor.
