- Oct 15, 2017
Hello All,
Just a small update on the Le Fleuron's backbone. My #1 object in this exercise is building it straight, STRaight, STRAIGHT! I have accomplished this after the glue has dried, but it requires some serious reinforcements as I need it to remain straight.
I decided to reinforce with 2 metal brackets along the join. First, a few layers of cheese cloth soaked with PVA, over which I've placed the 2 brackets to guide my drill.
After drilling, dry fit the brackets via bolts, keeping in mind not to over tighten.
Another consideration, placement of the join must be in between bulkheads as not to interfere with them.
And finally a saw cut around the perimeter. Looking down at the backbone now constructed, I get a sense of how large this model will be. Both rewarding and a little alarming.
The reason for using 2 brackets can now be seen. The top bracket will be removed when the shell is finished to facilitate the removal of the top half of the backbone and bulkheads.
Next step is cutting 6mm slots for the bulkheads. Then no more construction for a while as it will take some time to dry fit the bulkheads, take many measurements, make some, hopefully not too many adjustments.
Thanks for following along!
Till next time....
Till next time....
