Le Rochefort 1/36 - Build Log by Moreplovac
Good morning, as Titoneri has already written, just leave it out. I didn't do it either, it just caused me problems with La Palme. As for the second question here, I have to admit that I don't really understand what you mean.
A little table addition to bridge the gap between sanding paper and sanded part... just a two piece of plexiglass, glued together for thickness and two holes matching diameter of a sanding cylinder.. suction action of an attached vacuum, keeps the plexiglass very tight...
On the bench.... during action...
All parts are almost done...
Hard to find some hobby time during Euro24...
Happy modelling..
The build continues with assembling few parts, including keel...
It appears to ended up OK. still some sanding is needed..
Also, I have cut the angle on the keel with a knife, file and sanding so will see end results..
Keel parts were glued together but was noted some curving on the keel so had to reassemble and glue them again with mora usage of wise and heavy objects..
End both parts...
Happy modelling...
