LE ROCHEFORT - Harbour yacht from 1787 1:36 by Tobias (Monograph by ANCRE)
Oups je suis vraiment désolé Tobias je me suis trompé je pensais que j’étais sur ma page .je vais effacer et mettre chez moi encore pardon
Oops I'm really sorry Tobias I was wrong I thought I was on my page. I'm going to delete and put at home again sorry
It's okay, that can happen, don't worry, your progress is remarkable as is all your work. I don't think you have to delete it, you can also move it.
The planks on the HZ are 2 mm thick, hard work bending. I sock them at least 6 hours for a big curve.
A small hint, there is a small error in the plans that all builders of Le Rochefort should be aware of. Here is the link to
Post in thread '"Start-up Conversations" and "Build Support-Tips, Advice" here.'
Report #134
Good evening dear friends,
before I start with the deck boards and planks I was busy with various superstructures.
Making the floorboards and planks, for the deck I chose boxwood and for the bulwark I chose Swiss pear, also known as service tree.
1. Image not glued
And here it is now glued.
1. Image not glued
Good evening Tobias. I like the choice of wood you have chosen. Obviously most top modellers love box wood, however the complimentary Swiss pear is a good one. Beautiful work as always. Cheers Grant
Witaj
Pięknie zrobiłeś poszycie wewnętrzne ,czy będziesz je kołkował? . Pozdrawiam Mirek
Hello
You did the inner plating beautifully ,will you be studding it? . Greetings Mirek
Hello everyone and good evening. @dockattner @AnobiumPunctatum @pianoforte @GrantTyler @Mirek @Uwek thank you for the comments and all the likes. A few pictures of the progress of the deck boards.
There is not much to say about the work. The calving is again imitated with tissue paper and the floorboards are worked with a plane.
Witaj
Bibuła robi swoją robotę ,uszczelnienia podłogi wyglądają super . Pozdrawiam Mirek
Hello
The tissue paper does its job, the floor seals look great. Regards, Mirek
