LE ROCHEFORT - Harbour yacht from 1787 1:36 by Tobias (Monograph by ANCRE)
In the next pictures you can see a little progress. First of all I noticed that I made a mistake with the last scupper. I installed it one frame apart and not at the same height as the pumps. I tried to fix it as best I could, but you can see it.
The beams of the front deck were fitted.
The rear was paneled inside.
And last but not least, I continued with the exterior planking.
And another picture for the gallery.
Thank you for your interest, see you soon.
Witaj
Pomyłka ludzka rzecz ,dla mnie Tobiaszu świetna praca a dobór drzewa rewelacja. Pozdrawiam MIrek
Hello
A human error, for me Tobiasz, great work and the choice of tree was amazing. Regards, MIrek
Just great Tobias! I wouldn't worry about the patch - I have about 20 ROTF.
I happy to know that I’m not the only one to make mistakes! ;)
Excellent work as always!
Witaj
Hello
We are all learning something new each day ..... also with such experiences
Everyone has to deal with patches at some point, but that doesn't detract from your excellent work. Saugut das Ganze.
Hi guys, thanks for the great feedback, I think we can live with these little patches. The one in the waterway is more clearly visible, the one outside almost not at all and once the battering ram is there you don't even notice it anymore. This was also the reason for the move, otherwise I probably would have left it alone.
Image source From the French forum of GD
Hello Paul, thank you for your help, although I don't think it can be the temperature. Water that boils is 100 degrees and evaporates, so the steam is also 100 degrees. But I could imagine that it is the length of time it is in the water bath or in the steam and that the steam process is gentler.
Steam can be much hotter
steam can be much much hotter than 100. If I had a much bigger pressure cooker I could use that
Hello everyone, thank you for all your comments and your interest.
The beam guide for the aft deck has been adjusted and the beams have been fitted. The first beams were wrong, I had used a board with 5.5mm instead of 4.5mm. The beams are fitted so that the planks fit neatly on them.
Here is a picture of our builder, if you look at it like that you can see that the captain could only get into his sleeping quarters on all fours, not very comfortable
Next I started with the interior work. First I nailed the boards of the rear panel, then I started on the partition wall and the doors and finally made the first window. How I made the window will be explained in the next post.
Thanks for stopping by, see you soon.
Witaj
Jak zwykle pięknie , dokładnie i to piękne drzewo . Okna Tobiaszu robiłeś używając frezarki ? Pozdrawiam Mirek
Hello
As usual, beautiful, precise and a beautiful tree. Tobiasz, did you make the windows using a milling machine? Regards, Mirek
Witaj
Hello
Hello Mirek, the windows are cut from 1x1mm thick walnut and a scalpel, I only made the bevels with the MF 70, I will show the manufacturing process in the next few days.
Witam Mirek, okna wycinane są z orzecha włoskiego o grubości 1x1mm i skalpela. Fazy wykonałem jedynie maszyną MF 70. Proces produkcji pokażę w najbliższych dniach.
A nice flow over the installed beams, Tobias. And good to see that you are building on the interior, with some nice panel doors and wall.
my dear friend Tobias
the partition wall and the doors and the window looks wonderful, well done
Good afternoon Tobias. Precise, accurate and beautiful. Cheers Grant
