LE ROCHEFORT - Harbour yacht from 1787 1:36 by Tobias (Monograph by ANCRE)
Thank you @RogerD @Herman @shota70 @dockattner @pianoforte @Mirek @Uwek @OlivierF @GrantTyler @Peter Voogt @Tony P for your comments and interest. Also thanks to everyone for the likes received.
Next I made the rudder, intended as a prototype from two different types of wood, walnut and pear, to see how it looks, but I might leave it. The main thing is the upper rudder passage in the aft deck. Two longitudinal beams with dovetails have to be installed here and an oval opening has to be filed. For this reason I built the rudder to see how everything fits.
Like everything in the rear, nothing has been glued yet because the next step is to install the windows. For this, the hinges and the side locks still had to be made. The hinges for the small cupboard door were also on the agenda.
The plan is that everything is movable, and the plan worked for the small cupboard door. I hope it works for the windows too. Since a window like this also has glass panes, these cannot be missing. Here I am using "Micro Crystal Klear" and I am attaching a picture of the product.
Last but not least, the hatch for the cargo area in the rear area, various brass parts are still missing and the second window and parts of the interior fittings, then the rear area will be finished. I hope I can get it done before our big vacation in Croatia.
I wish you a wonderful Sunday, see you soon.
Dear Tobias
you are doing very accurate and beautiful work, as usual :) Okay
Frame construction of the rear windows:
Step 1:
Make a template, in my case I used a slightly firmer cardboard. I cut this until it fits.
Step 2:
On the cardboard, I mark the upper edge on the inside with an arrow and stick double-sided tape on both sides.
3rd step:
Here I make 6 small strips 1x1mm with a slight overhang.
Step 4:
Glue the two outer strips on. The advantage of the window frames is that they are not mitred. Then I adjust the upper and lower strips and fix them with superglue. Let the whole thing dry a little and very carefully remove it from the template (if it breaks, do it again straight away).
Step 5:
Now for the center cross, place a small piece of double-sided tape on the vice of the MF70 and mill it halfway.
Step 6:
Now place the two struts next to the window, adjust them to the shape of the window and glue them.
Step 7:
Once the cross has dried, align it on the frame and mark it. Fasten the frame back onto the vice with double-sided tape and mill the marked frame.
Last step:
Carefully remove the frame again and place the cross in the joints and then mark the inside of the cross on the frame. The cross is also fixed to the vice again with double-sided adhesive tape and the ends are milled. Now glue the cross and the frame together, sand off the excess, clean everything and you're done.
I hope I was able to explain it clearly. If something is unclear, just ask.
It's always to see your updates with close up pictures to be reminded of just how good your work really is. Ecellent!
Witaj
Tobiaszu doskonała praca, ster cudo bardzo podoba mi się grusza połączona z orzechem . Pozdrawiam Mirek
Hello
Tobiasz excellent work, the rudder is wonderful I really like the pear combined with the walnut. Best regards Mirek
Sorry, if I already asked this already once, but the nailing on the hatch cover is great
How you do this? Drilling with 0,3mm and ?
Thanks @Steef66 @Herman @RogerD
Hello everyone, Uwe @Uwek asked two good questions about how to approach straight drilling, Paul @dockattner was also interested in it. The same goes for the production of the hinges.
Now I would like to add two pictures about drilling. I have attached a stop to my small drill and marked the board with a pencil line where the drill bit goes into the wood. Then the holes are drilled one after the other, next row, the stop is moved and drilling continues.
To make the hinges, I use a brass tube with an outer diameter of 1.2 mm and a wall thickness of 0.4 mm, a brass wire of 0.4 mm, and the whole thing is soldered together. In the next step, I use a 0.5 mm thick brass sheet. This is also soldered to the existing parts. For soldering, I use a solder paste and a small Bunsen burner or a soldering iron, depending on the case. I cut small strips from the brass sheet, depending on the width of the strips required.
Preparing the brass strips:
Here I take a 5mm thick wooden board, stick double-sided adhesive tape on it and fix the brass sheet on it, then set up the small table saw and cut off small strips. The advantage of this method is that it doesn't tear, bend or wrinkle. I adopted this method from Johann @archjofo .
As for the construction of the hinges, I will let the following pictures speak for themselves.
Finally, everything is blackened and installed in the ship; with a bit of luck, it will then be movable.
As mentioned earlier, the loading hatch will have a few brackets on the side to hold the frame together. To drill the holes in the metal bracket, I cut a piece of wood to size and milled a notch into which I placed the bracket and then drilled the 0.35mm holes.
Preparation for assembly in the rear area, I have embedded the wood here using bale matting.
The fine caulking (sealing) with tissue paper between the floorboards comes across very well, as does the slightly reddish tone on the outer floorboards, better than I expected.
A nice tutorial with the in between steps, Tobias.
