Looks great your build is progressing very quickly.Foremast is built. View attachment 308536
Thanks, Tony. I’m fully retired now. The first week of retirement was sitting around binge watching Netflix and Britbox. Now I’m back in the swing of things. Downloaded R. C. Anderson yesterday and researched spritmasts and tops. According to him, my tops will be pretty close to the way the French did it. However, the masts aren’t supposed to be squared at the tops. The cheeks under the lower crosstrees are supposed to be therefore padded. Too late now!Looks great your build is progressing very quickly.
Vic, why shouldn't tops be square. On Victory, the top is square. It's different on different ships.However, the masts aren’t supposed to be squared at the tops.
And I'm embarrassed by these side and front trims that are installed on top of the vulings. How are they really supposed to behave?Thanks, Tony. I’m fully retired now. The first week of retirement was sitting around binge watching Netflix and Britbox. Now I’m back in the swing of things. Downloaded R. C. Anderson yesterday and researched spritmasts and tops. According to him, my tops will be pretty close to the way the French did it. However, the masts aren’t supposed to be squared at the tops. The cheeks under the lower crosstrees are supposed to be therefore padded. Too late now!View attachment 308667View attachment 308668
Just following the directions. I don’t know what those wood slats are for. Sorry I embarrassed you.And I'm embarrassed by these side and front trims that are installed on top of the vulings. How are they really supposed to behave?
The Victory is a British ship. They had square masts from the cheeks up in the early 17th Century, according to Anderson. He said the Dutch and French ships had round ones until the early 18th Century. They had to add extra support to the insides of the cheeks to keep them straight and firmly attached to the mast.Vic, why shouldn't tops be square. On Victory, the top is square. It's different on different ships.
Good morning Vic. I've been away for a while and it is good to catch up with your build. I agree with you that the 2x2 is too large. I have had the same issue time and time again with my build and being in SA the availability of wood is limited. I used my circular sanding bit on my dremel (low speed)(I have no fancy tools) to reduce the width of the 2x2. It works pretty well after a few practice runs. Cheers GrantI see what you are saying. My 2mm x 2mm sticks are too big to put that many on them. I'd have to find a way to make them thinner. Are these instructions for the Soleil Royal? Also, you posted a picture of the halyard ropes going through a knight (knecht). Did you do the same thing on the main mast? Do you have more pictures to show how that was rigged from top to bottom?
I followed Pauls method...clearly did not come out like Pauls, however worked for me.And here is how I did mine... https://shipsofscale.com/sosforums/threads/vasa-1-65-deagostini.5904/post-201256
I started with round stock that was larger in diameter than needed...sanded down everything but the future squared portion on a mini-lathe to the required mast dimension...and then did what is shown in the post above to create the square area. In my case I needed the 'flat' on the squared portion to equal the width of the round portion (as Kurt described above).
Another option is to make a stand-along square section and pin and glue it onto the round section (that is, make the mast in segments along its length). The challenge here would be to keep everything straight... There will be a visible seam but no one will notice because they will be admiring the paint job you did on the horse figurehead.
Nice Vic! Looking at @Heinrich log, researching the historical correctness of a ship is more of a debate of many expert papers, documents, and opinions than an exact science. It is an interesting experience for sure. Great work on your Le Soleil. Cheers GrantThanks, Tony. I’m fully retired now. The first week of retirement was sitting around binge watching Netflix and Britbox. Now I’m back in the swing of things. Downloaded R. C. Anderson yesterday and researched spritmasts and tops. According to him, my tops will be pretty close to the way the French did it. However, the masts aren’t supposed to be squared at the tops. The cheeks under the lower crosstrees are supposed to be therefore padded. Too late now!View attachment 308667View attachment 308668
