Me too. But the designer/researcher insists it is correct (and that there was variation between designs/ships).This is a late comment (too late). But I find that variance to be odd.
frustrating!Thanks! I have found it a bit hard for me, mostly with planking, but then this is my first and only full plank on bulkhead model. I found out afterwards they recommend it for more advanced builders, but I'm slogging my way though it.Looks like a VERY demanding and fiddley build. I, too often encounter illogical, or impossible features designed into these models.frustrating!
Great work thus far!
Pete
Good morning. Beautiful work. Thanks for the detail build log. You are getting the detail spot on. I love the barrels. I just bought a resin printer and still need to work out how to design the StL files. Cheers GrantIn researching information on the Carrack and similar ships, I ran across information on the "Pepper Wreck", a fairly large 17th Century Nau, or Carrack. This ship made regular trips from Portugal to India, to obtain pepper in particular (thus the "Pepper Wreck"), as well as many other items. Texas A&M University has made a Virtual Representation of this ship, and while I haven't found the complete representation, if it exists, there is a detailed PDF of the process with a lot of good information here.
One of the interesting things in this PDF is the amount of on-deck storage of barrels and other items that they theorize was on the ship. I never thought about much storage of such items in areas other than the hold or elsewhere below deck, but I imagine that at the beginning of a voyage, it would make sense to have much of the more expendable, i.e. more easily spoiled, goods above deck, assuming it would be used early into the voyage. And while that Nau was an ocean-going ship, and this Carrack/Nau a much smaller Mediterranean ship, I assume the idea would still apply.
This longitudinal cross section shows how the cargo was distributed on this ship:
And another view of the main/gun deck with its cargo:
Naturally, that would limit the use of the guns, but I imagine those barrels would be used early into the voyage, and these were, after all, trade ships with protection from pirates and other ships, and not warships.
They also modeled many of the details of this ship, including cargo, for this virtualization, and include this image for the barrels:
In looking at the cross section and other views, it appears that most of the barrels above deck were Quarto size, which they list as 0.98m x 0.64m in size, almost exactly the size that would later be called a Hogshead by the British. I used this size as a basis for my model, to have an amount of barrels "sprinkled" about the main and other decks (amount and location to be determined later). I also assumed that the hoops on the barrel were half-round saplings, often used to wrap early barrels, before iron replaced them. I have seen rope used in a similar manner on smaller barrels, but not on ones this large.
Anyhow, here is an image of my 3D model, modeled in Fusion 360:
I used the Quarto/Hogshead dimensions (although of course it can be scaled and printed to any size), resulting in this STL model:
The gaps between the staves are exaggerated so they will be more visible on the printed model. If you like, you can download the 3D STL model at the bottom of this post.
Anyhow, my son made a bunch of these barrels for me. With a resin printer, it takes no longer to make dozens than it does one, so that gives me a lot to play with. I sprayed most of the barrels white, and then painted them with Army Painter Speed Paint:
Speed Paint is fairly new. It is brushed on liberally, and sinks into low spots like a wash, giving a paint, wash and highlight all in one. It ended up pretty light over the white paint, so required several coats. NOTE: Wait for it to dry for several hours or overnight before applying the next coat, or it will soften and remove/blend the first coat. Also, little "pieces" of paint from the crevices will surface and float around. Sometimes you want that, but not always.
I experimented by painting some barrels brown or tan, and spraying others khaki or tan spray paint. More than one coat hides detail, so try to do it only once. The tan or khaki spray got closer to the desired color with less coats of Speed Paint.
I thought I wanted to highlight the wooden hoops, so did that with some, but they seemed too "stripey", so they got more coats.
In the end, I ended up with a variety of colorations, markings, etc. giving a good variation in barrel colors:
I know they look rough up close, but the variation and defects, I think, help in a way. They will look better, more like this, when placed on the model:
I think they will work well on the model. But as I said, they will be added later, after all other deck details have been placed.
Thanks, Grant. As I said above, I use Fusion 360 to design 3D models. It's free for hobbyist use and is a great program. If you need help or ideas, let me know.Good morning. Beautiful work. Thanks for the detail build log. You are getting the detail spot on. I love the barrels. I just bought a resin printer and still need to work out how to design the StL files. Cheers Grant
Thank you so much. I admire your precision work very much, so really appreciate your comments.Hello Signet, once again I had a lot to catch up on and I am enthusiastic about your great work. Super job with all the details like the pumps and the barrels, top notch.
