Such wonderful work my friend! Every detail cared for and the overall result is breathtaking.
Thank you, PavelSuch wonderful work my friend! Every detail cared for and the overall result is breathtaking.
Thank you, Uwe. The work is not progressing as quickly as we would like. One pair of shrouds takes a lot of time. First, braid the middle part, then tie the deadeye in the shroud, then 3 benzels, then the turnbuckle. In words it doesn’t seem difficult, but in reality it takes a lot of time. I will try to post more often
You Will NEVER be braveAnd the model's appearance as of yesterday evening.
View attachment 405265View attachment 405266
Construction continues...
Ты НИКОГДА не будешь храбрымYou Will NEVER be brave
if you do not get hurt.
You Will NEVER learn,
If you do not make mistakes,
You Will be successful if You do not encounter failure.
I HAVE FOUND OUT THAT YIU HAVE DONE WELL AS THE 1. Th TI
have two questions: Is the 1.
Th throud on each lower mast Seizet from top to bottom? It is important, as it comes in contact with the lower sails.
2 Nd. Are. are you going to add an opening line on the closet gunports? I like very much the closet gunports, instead of the gummi guns.
Tengo dos preguntas: ¿La primera cubierta de cada mástil inferior está colocada de arriba a abajo? Es importante porque entra en contacto con las velas inferiores.
2 No me atrevo a agregar una línea de apertura en las troneras del armario. Me gustan mucho las troneras de armario, en lugar de las pistolas de goma.
I cannot get a UK text for the moment without a failure
I HAVE FOUND OUT THAT YOU HAVE DONE WELL of seising 1. Throud .I
2 No me atrevo a agregar una línea de apertura en las troneras del armario. Me gustan mucho las troneras de armario, en lugar de las short guns
The first question, as I understand it, is about the capping of the front shroud? yes, it is braided throughout its entire length.I
it was to open and close the gunportsThe first question, as I understand it, is about the capping of the front shroud? yes, it is braided throughout its entire length.
But I didn’t quite understand the second question. Somehow it’s not clear to me the translation turned out
The ports will remain as they are nowit was to open and close the gunports
ONE OF THE MORE DIFFICULT PART UN THE BUILD- BRAVOIt remains for me to make one decorative regel to complete the design of the nose. I cut it out according to the pattern. The photo shows a cut-beam on the starboard side. Without it, this curved regel cannot be adjusted. The beam is still in work, not finished
View attachment 368991View attachment 368992View attachment 368993
My question came from here. to open the ports when closed.Hello Alessandro, I hope these photos can help you.Frank
as you are the Captain, the orders are yoursThe ports will remain as they are now
